Please someone help!!!!!!!!!!!!!!!!!!!!
Old Mar 13, 2007 | 07:57 PM
blk_teg_sleepa's Avatar
Default Please someone help!!!!!!!!!!!!!!!!!!!!
I have a 97 Acura integra LS and when I start hitting the break (mainly holding the brake at a stop) something in the engine starts to rattle like a peice of metal clancking around. Only happens at the stop and the car must be in drive and in gear. When I shift to neutral, it stops, but once I go back into gear, the rattle will start again. Please any information will help. Thank You.
Old Mar 14, 2007 | 10:04 AM
deftonerider's Avatar
ok first off check to see ig the noise is present when your foot is off brake secondly how is the car in drive and in gear is it a stick or an auto
Old Mar 14, 2007 | 10:30 AM
AntonioFF's Avatar
check your clutch if its a standard tranny
Old Mar 14, 2007 | 12:18 PM
antiricer's Avatar
Default Re: (deftonerider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deftonerider &raquo;</TD></TR><TR><TD CLASS="quote">ok first off check to see ig the noise is present when your foot is off brake secondly how is the car in drive and in gear is it a stick or an auto</TD></TR></TABLE>
yea i was thinking the same thing is it stick or auto
Old Mar 14, 2007 | 01:21 PM
Perfectionist's Avatar
Default Re: Please someone help!!!!!!!!!!!!!!!!!!!! (blk_teg_sleepa)
Heat shield on the exhaust rusted and loose?
Old Mar 14, 2007 | 02:51 PM
SOrry didn't even realize I wrote it like that. Its aan auto and it only happens when my foot is on the brake. It is definitly coming from the engine.
Old Mar 14, 2007 | 02:56 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (blk_teg_sleepa)
As said before, it is probably a heat shield. Have someone sit in the car with their foot on the brake, etc to reproduce the noise. Pop the hood and find the source.
Old Mar 19, 2007 | 03:50 PM
Default Re: (Dogginator)
I tried that but I cant find where it is coming from. But when I push the front right corner of the valve cover down, the noise stops.
Old Mar 19, 2007 | 04:01 PM
Dogginator's Avatar
Daisy... Daisy...
Is the valve cover loose?
Old Mar 19, 2007 | 04:05 PM
Vtec_Dude's Avatar
i think if that happens he would have oil leak. i was gonna say something about the tranny but when i read the valve cover part i totally got stumped.
Old Mar 19, 2007 | 04:09 PM
turb0teg's Avatar
If the whole car is vibrating then its your motor mounts (or just one mount)
My friends teg does that. If its just a rattle, check the shield like someone suggested.
Old Mar 28, 2007 | 09:33 AM
Default Re: Please someone help!!!!!!!!!!!!!!!!!!!! (turb0teg)
now that is read it again it does sound like you might have broken a mount the one located in the timing belt area makes a mean rattle at idle when broken the tranny one breaks a lot too. drive the car, put in the the second gear selector thing and drive to like 5000 rpms then let off the gas and see if it rattles. a rattle hear should defenitly have you looking for broken mounts or loose bolts in the frame (crossmember if applicaple, rack and pinion, etc)
coot_er
Aug 23, 2007 02:02 PM
Integra9000
Jan 25, 2007 12:27 PM
canada-civic
Dec 14, 2004 07:54 PM
crookedletterd
Sep 16, 2001 07:14 PM
