integra problems HELP
Old Mar 10, 2007 | 07:57 PM
projectlude's Avatar
Default integra problems PLEASE HELP!!!!!!
ok to start out my car ran good(96 integra se)...but i decided to do a tune up, so i did the plugs,wires,cap,rotor...after i did all that i didnt get any spark...so i put all my original stuff back in to see if that was the problem and still no spark..so i did some research on here and found out that it might be my ignition coil, so i took the one out of my 95 civic ex, my car started and ran but it didnt have any power, i mean i would floor it and take it to 7grand but it wouldnt pick up..so i went down and bought a brand igniton coil ($97)and still now power, o yah and it makes a loud whistling noise out of my intake, i have no idea what the problem is , and before i put it in the shop and pay someone an assload of money i would like to see if you guys could help me solve this problem myself.. thank you all in advance..
Modified by projectlude at 12:18 PM 3/11/2007
Old Mar 10, 2007 | 08:12 PM
Default Re: integra problems HELP (projectlude)
help help help..
Old Mar 10, 2007 | 08:30 PM
o0oz's Avatar
maybe u have a stuck throttle? iono...
someone help this guy out.
Old Mar 10, 2007 | 09:27 PM
integdriver4's Avatar
a whistle coming from the intake sounds like it would be a vaccum problem which i believe would cause a problem with power, in your case not having any power. there is a chance that you could have damaged one of the hoses while doing the tune-up, so check that. the easiest thing to do is just to find the vaccum leak and temporarily wrap it in electrical tape then test drive it. good luck
Old Mar 11, 2007 | 07:30 AM
Default Re: integra problems HELP (integdriver4)
that is what i thought it was.. i looked around for a vacume hose leak put i couldlnt find anything...i will have to look closer... thanks for the help....
Old Mar 11, 2007 | 11:14 AM
cant find a vacume hose leak anywhere.....any other input? i need my car back by tomorrow i have class, and then work...help please
Old Mar 11, 2007 | 03:21 PM
DeadVet's Avatar
check and make sure your spark plug wires are in the right order.
Old Mar 11, 2007 | 04:17 PM
Default Re: integra problems HELP (1TurboHatch)
i thought that too, so i search on here and found what it should be...
4321 -across the valve cover and on the -distributer it goes
34
12
right?
Old Mar 11, 2007 | 04:23 PM
99Geeezer's Avatar
The firing order is 1-3-4-2. The #1 cyl. is the one closest to the pulleys.
Old Mar 11, 2007 | 05:14 PM
Default Re: integra problems HELP (99Geeezer)
https://honda-tech.com/zerothread?id=1653400
that is what i have on my car.. is it the same for my b18b?
Old Mar 12, 2007 | 05:16 PM
still have no power....tryed checkin the cat converter but that is fine.... and i tryed resetting the ecu and still no power, just the loud whistleing noise from the intake...any other input? thanks.
Old Mar 12, 2007 | 06:29 PM
any info...come on this is honda-tech someone must know whats wrong...HELP..
Old Mar 14, 2007 | 06:06 PM
problem solved....piece of metal in the intake filter came off and got lodged in the inake pipe..
Old Mar 14, 2007 | 06:14 PM
thecunningham's Avatar
Default Re: integra problems PLEASE HELP!!!!!! (projectlude)
DID YOU CHECK THE TIMING ????????
deodorantlowkey
Suspension & Brakes
Dec 8, 2014 05:43 PM
badboiz530
Jul 15, 2007 07:08 PM
1320EF
Mar 17, 2005 05:52 PM
da9shotime
Mar 10, 2004 12:46 PM
