Bad Engine Block ??
Old Mar 14, 2007 | 09:40 AM
Extreez's Avatar
Default Bad Engine Block ??
Just noticed today on 93 integra, a midrange of white smoke coming out of tail pipe, and spitting out water, green dots in water (possibly radiator), but could this be caused by maybe becuz the engine could of been hot, or ???
Old Mar 14, 2007 | 11:36 AM
Sam92Teg's Avatar
Default Re: Bad Engine Block ?? (Extreez)
blown head gasket maybe?
Old Mar 14, 2007 | 12:46 PM
Dealer Leaf's Avatar
Default Re: Bad Engine Block ?? (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">blown head gasket maybe?</TD></TR></TABLE>
If bubbles come put of top of rad when car is running its the head Gasket.
My 91 S has a mild amount of smoke and a small drip. I jsut rebuild the engine. I suspect its the Cad making the smoke.
If your coolant Level and oil level arnt dropping. Check to mmake sure you havent gotten water in y our CAI if your running one
Old Mar 14, 2007 | 12:57 PM
AnthraxVX's Avatar
if you have coolant coming out of your tailpipe then coolant is entering your cylinder via the head gasket and going through exhaust. check your compression on each cylinder
Old Mar 14, 2007 | 03:44 PM
Extreez's Avatar
Default Re: Bad Engine Block ?? (AnthraxVX)
check radiator coolant level it looked perfectly fine, full to top, only does this when the car is being rev'd up or speeding, so im not sure....
benjamin
Jul 2, 2022 11:49 AM
NENET
Jun 19, 2010 11:02 AM
honda_hackett
Sep 8, 2009 01:45 PM
Silvteg95
Aug 8, 2005 04:24 PM
85civic
Aug 29, 2004 03:21 PM
