Nitrous = Forced Induction
I've noticed a lot of people on this forum don't consider nitrous as forced induction. Or they will call their setup N/A even if theyve got nitrous. So i just want to hear what all of you think. So vote.
Your forcing more air into the engine... which is similar to a turbo.. only it uses a gas to do so.. which requires no compression of air, since it's pure oxygen...
anyone can bolt it on thier car.. not everyone can run it without blowing something up...
Forced induction means what it says, FORCING additional air/fuel under pressure into the combustion chambers. Nitrous, IMHO is not "forced induction".
[Modified by ThePunk, 10:12 PM 2/2/2002]
okay
to make fire you need
1) spark
2) fuel
3) oxygen
a NA motor sucks in air which is about 20% oxygen and 70% nitrogen (which is inert)
a FI motor sucks in the same air, but more dense, so its got more O2 in it.
adding N2O to the intake means that there is less air and more O2 since when the N2O is in the combustion chamber, it breaks down to N and O2 which makes more bang and you get more power.
so no its not literally FORCED in, but you're making the engine burn more O2 so in many ways it should be classified as FI, but you're right the engine is not mechanically inhaling more air.
i guess when considering the intake / exhaust of the engine, you would like to think of it as a NA motor, but as far as tuning, stress, temperatures, power, combustion chamber dynamics, its FI all the way.
1) spark
2) fuel
3) oxygen
ThePunk: with a nitrous system you are forcing more air, thats under pressure in the bottle, while adding more fuel. so how is this not forced induction?
falconGSR: you dont burn O2, you burn fuel.
art
2) you need O2 and fuel to make fire. The O2 is being "CONSUMED" in the process. That's burning to me.
Please get it straight.
Better yet why have a throttle body, intake manifold, or MAP sensor etc? Better yet why dont we just plumb injectors directly into the head and nitrous jets? Oh hell now we wont have an air/fuel ratio to worry about. Man I think we are on to something if you dont need oxygen.
art
art
With forced induction (turbo or S/C) The Fuel/air charge is physically being FORCED into the cylinder under pressure.
RX7R2: NOS is forced induction
falconGSR: naws
RX7R2: better terminology, it is "unnatural aspiration"
falconGSR: hmmm yeah
RX7R2: meaning that the intake charge contains more oxygen than ambient
falconGSR: well, oxygen thats held in a molecule
RX7R2: I think they were getting too hung up on the semantics of the
word "forced"
falconGSR: until burned
RX7R2: doesn't matter, it is still more than ambient
falconGSR: yeah
RX7R2: the oxygen density of the intake charge is higher than normal....that is
forced induction
falconGSR: right
falconGSR: cause thats what makes more power...more O2 and fuel
RX7R2: correct
RX7R2: because during combustion, it is the oxygen molecules that bond with the carbon molecules in gasoline to create the power
RX7R2: it would appear to me that they are idiots
falconGSR: the C and O bonding is a byproduct of the combustion process though, right? i mean CO is from the two elements being present in an unbonded state and the high pressure and temperature are what causes them to fuse...
RX7R2: correct
RX7R2: and it isn't the fusing of them that makes the power, it is the breaking up
of the carbon chain contained in Gasoline
falconGSR: right
falconGSR: cool i recall something from my state sponsored education
RX7R2: that is why the NOS alone doesn't give you power, it's the increased amount of fuel used
falconGSR: yeah
RX7R2: so it isn't oxygen that makes power, it's the fuel
falconGSR: the O2 is needed as a catalyst to promote the burningg process...just
like in any fire
RX7R2: turbo, nos, supercharger...they all serve one purpose...to force more oxygen molecules in the chamber
RX7R2: it's up to the ECU/tuner to add the required fuel to go along with that increased amount of power
ok i think we beat it to death.
falconGSR: naws
word "forced"
falconGSR: yeah
forced induction
falconGSR: right
RX7R2: correct
RX7R2: correct
falconGSR: right
falconGSR: yeah
like in any fire
If I had to classify Nitrous, I think it would be "FORCED ASPIRATION"
The engine still breathes like normal, but it is being force-fed nitrous, so forced aspiration.
N2O breaks down to two molecules of nitrogen (used as a buffer inside the combustion chamber) and one molecule of oxygen. At 525 degrees fehrenheit the N2O is broken down and the extra oxygen is then free to mix with the additional fuel you add with the nitrous system. If you only added more fuel obviously it wouldn't burn since there would not be enough oxygen to "go around" for all of the extra fuel. Basically N20 is allowing you to burn more fuel by adding oxygen chemically instead of compressing it . So why not add pure oxygen? The combustion would be to hot and fast....you would melt your motor quick!
There are four elements required for combustion:
1. Air
2. Fuel
3. Spark
4. Compression
Just thought like being an ***.
The way I see it, the following is forced induction:
Supercharger, Turbocharger
Forced Induction, in my vocabulary, is any type of system that does not use the natural "sucking
" power of the piston traveling downward to suck in air.
Nitrous Oxide is not forced induction. I just call it a power adder, nothing more.
Instead of classifying it as forced induction, NOS needs it's own categorization because it does not fit the other two types.
Of course this is only my perspective.
[Modified by ILR, 11:41 AM 2/3/2002]
1. Air
2. Fuel
3. Spark
4. Compression
" power of the piston traveling downward to suck in air.Nitrous Oxide is not forced induction. I just call it a power adder, nothing more.
Yeah, have you seen an oxy acetylne torch(spelling*) When you add the extra oxygen it just rips right through the metal!
the IDRC quick 8 classifys 3 things as a "power adder" (depends on how u want to call it FI or not)
1. turbo
2. superchager
3. nitrous oxide
thats the rules they go by
1. turbo
2. superchager
3. nitrous oxide
1. turbo
2. superchager
3. nitrous oxide
1. turbo
2. superchager
3. nitrous oxide
