Camgear degrees..
Generally speaking on a turbo B18C1 running 15-20 psi with standalone unit and tuned nicely, what degree of timing on the camgear are good to start out with. I know dyno would needed and it will but just some base numbers would be great. Any examples out there?
Retarding the intake cam allows for dialing overlap out. Advancing the exhaust allows for better exhaust scavaging. I have mine dialed in at 2 degree retarded on the intake, and 2 degrees advanced on the exhaust. I picked up 15 more hp at the wheels with that adjustment alone. This is with a LS block though...but you can always just use my settings as a starting point.
rioninja
Apr 10, 2002 08:39 AM
