help with my turbo set up
Old Feb 4, 2002 | 09:12 AM
rob1208lv's Avatar
Default help with my turbo set up
hi i recently purchaced and installed my drag3 kit, on my ls motor. i upgraded to rc310 injectors, greddy profec b controller, a new cluch/flywheel, and a missing link. what are some other up grades i should get???? fuel pressure reg?? fuel manage?? better wastegaqte
and how should i build my exhaust?? right now i have a flex tube clamped to my downpipe, with 3" pipeing to a hollow cat, through a apei dunk muffler, with no resonader...
Old Feb 4, 2002 | 09:36 AM
psicrxsi's Avatar
Default Re: help with my turbo set up (rob1208lv)
get an ignition upgrade...very important, tial 35mm wastegate would be a better wastegate than the one that drag uses which is the turbonetics one. get some sort of fuel comtroller....the apex s-afc would be good for your car. yer exhaust system seems pretty decent.
Old Feb 4, 2002 | 09:55 AM
threatcon13's Avatar
New User
Default Re: help with my turbo set up (psicrxsi)
hondata 2b,swap out to 440s.
Old Feb 4, 2002 | 09:59 AM
Pritos's Avatar
New User
save your money on the ignition and buy a Tial instead. Your stock ignition is sufficient.
Old Feb 5, 2002 | 06:02 AM
rob1208lv's Avatar
tt
Old Feb 5, 2002 | 06:20 AM
maxim's Avatar
Default Re: help with my turbo set up (Pritos)
Yeah, with modest boost(6-8psi) Honda ignitions are just fine. The next upgrade should be the Tial WG and then get yourself Hondata 2b. If I had the money that's what I would do and ditch my SAFC or VAFC.
[Modified by maxim, 9:39 AM 2/5/2002]
SSgtGage
Jan 8, 2015 03:06 PM
OnPointDX
Oct 25, 2003 09:03 AM
b16ahybrid
Dec 28, 2002 02:58 PM
nolovenodie
Nov 8, 2002 02:43 PM
