12 psi??
Old Feb 1, 2002 | 12:04 AM
CM-R's Avatar
Default 12 psi??
Is it possible to use 12 psi on stock internals on a B18C1 with proper fuel management??....I'm planning on just getting a vafc and 370cc injectors and 6:1 vortech disk and dyno tuning time....any info would be helpful thanks...
Old Feb 1, 2002 | 12:07 AM
austrian type-R's Avatar
Default Re: 12 psi?? (CM-R)
I would say it is on the edge, but I highly recommend a standalone. Save you the money on the CAFC and the FMU. 440cc + Hondata or any other brand of ECU
Old Feb 1, 2002 | 12:14 AM
CM-R's Avatar
Default Re: 12 psi?? (austrian ITR)
Will i still be able to keep my stock internals and run 12 psi with hondata and 440cc injectors?....the reason for me not doing a rebuild is because i have my turbo already installed and i dont want to remove it to put in pistons and rods..etc..
Old Feb 1, 2002 | 12:27 AM
VaporTrail's Avatar
New User
yes, with properly tuned Hondata, 12lbs can be done on a stock internal GSR
Old Feb 1, 2002 | 12:30 AM
CM-R's Avatar
Default Re: 12 psi?? (VaporTrail)
Thanks for the info i'm going to buy hondata stage 3b with a new ecu from SGT....any more info would be helpful
[Modified by CM-R, 1:30 AM 2/1/2002]
Old Feb 1, 2002 | 01:58 AM
SYDNEYSIDER's Avatar
But will the motor last???I mean aint it too high???Im going to get haltech e6k, Im planning on 8-10psi....is 12 reasonable??or just strip use?
Old Feb 1, 2002 | 03:58 AM
Default Re: 12 psi?? (GS-R_ocks)
Haltech on the B18C works great! I´ve one installed myself and got some help from Dirtylude.
Old Feb 1, 2002 | 10:33 AM
CM-R's Avatar
Yea will my motor last if i do 12 psi as a daily driver??....i'm thinking of sticking to 10 psi if 12 is too much....
Old Feb 1, 2002 | 10:54 AM
VaporTrail's Avatar
New User
like anything else, the more you rag on it, the faster it will wear out. If you want to keep it reliable, keep the boost down to 7lbs, and turn it up at the track
Old Feb 1, 2002 | 11:22 AM
CM-R's Avatar
Yea that does make sense...thanks again
Old Feb 1, 2002 | 02:08 PM
11secdx's Avatar
we boosted a gsr for about a year, on 10 psi. on 93 oct. and sometimes 12 psi on 110. racing at the track almost every week. daily driven. we pulled it apart , the other day, and found, that it looked excellent on the inside. 310 injectors,vafc.
Old Feb 1, 2002 | 02:22 PM
falcongsr's Avatar
What is this crap?
i think you'll have some traction problems on the street above 8psi anyway.
Old Feb 2, 2002 | 03:03 AM
CM-R's Avatar
Default Re: 12 psi?? (11secdx)
was this a stock block on the gsr or was it built?...cause my block is stock...
Old Feb 2, 2002 | 11:49 AM
intekragsr's Avatar
I heard i cannot use the VAFC on my a turbo setup. ???? so now i get the impression i can??? i am about to sell mine. Please tell me how to use it with my turbo before i sell it. Thanx
Old Feb 2, 2002 | 12:45 PM
drifter's Avatar
Default Re: 12 psi?? (intekragsr)
will a stock ls be able to handle 12#'s with a hondata and 440's
Old Feb 2, 2002 | 02:31 PM
DLB1994's Avatar
Default Re: 12 psi?? (drifter)
yes
Old Feb 2, 2002 | 02:34 PM
DLB1994's Avatar
yes u can use it dont sell it you will make more power with it turbo then when you was NA
Old Feb 3, 2002 | 04:44 AM
FIxALPHA's Avatar
My own experience:
Im running a 6:1 disc and 450cc injectors with the VAFC. (Holley fuel pump).
At the track with 114 octane, I've run safely at 11.5psi.
At the street, 94 octane, at about 7psi.
Ive had the motor for a year with well over 100k mi on the 95 block.
However, I dont know how much longer it will last, but as of right now it's doing fine.
Ive had this setup for almost a year now, Im sure it will last longer if I don't beat on it....
At least 2-3 times a week, I do top end runs in this stretch of rt 287 (Bridgewater, NJ). I start out at 4th gear and end at almost the end of 5th. I know it's stupid (top end runs with boost=kaboom!!!) but it sure wakes me up and I feel good about going to work.
Old Feb 3, 2002 | 08:28 AM
synergy004's Avatar
Default Re: 12 psi?? (FIxALPHA)
well just get the right tuning. MARK C the Administrator for this site has been boosting on his teg for awhile. After about 2/3 years and riding in his car a couple times, it seems to me that the motor is still strong. Car is still fast and sounds mean. BUt wear and tear will break any motor in the long run.
god luck
Old Feb 3, 2002 | 10:22 AM
PROFILES2000's Avatar
Default Re: 12 psi?? (synergy004)
isnt his motor built?
god luck
Old Feb 3, 2002 | 01:15 PM
11secdx's Avatar
yes, it is a stock gsr. internals, as well as the head was all stock.
Old Feb 3, 2002 | 01:35 PM
BoostedSi's Avatar
440 + hondata...yes. How good of a condition is ur motor in? Compression checked? If compression checked out ok...just make sure u tune that poo poo with enough fuel and just constantly watch out for any leaning out or detonation and u'll be fine.
MotorMatrix.com
Dec 18, 2002 06:15 PM
B17aTrbo
Aug 2, 2002 01:57 PM
Nate B
Jul 12, 2002 09:31 AM
NeXtLeVeL_TyPe_R
Apr 17, 2002 10:37 PM
jamal-188
Dec 12, 2001 08:17 AM
