Drag 3 install problem/question
Old Jan 31, 2002 | 10:15 PM
intekragsr's Avatar
Default Drag 3 install problem/question
I dont know exactly waht it is called, but when I had to take off my intake, I needed to remove that black 3 way tube. One end of it goes to the valve cover, one end goes to somewhere in the throttle body, and the other end goes to the engine. I know I need to take off the valve cover part and replace it with a small filter, but what about the other 2 points? what do I plug it up with or do I put a filter on those too?? im really confused. Thanx for the help
Old Jan 31, 2002 | 11:01 PM
b18bvudoo's Avatar
New User
Default Re: Drag 3 install problem/question (intekragsr)
thats a coolant line. you need to connect it with a hose. and yes the valve cover can get a breather filter.
Old Feb 1, 2002 | 12:06 AM
Anthony K's Avatar
New User
Default Re: Drag 3 install problem/question (vudoo666)
You should connect that coolant hose to the throttle body.
Mullen
Aug 3, 2010 10:52 AM
nateb22
May 21, 2009 07:09 AM
ShinotakuX
May 14, 2008 09:55 PM
Frost_1097
42
Jan 12, 2007 02:56 PM
Prelude91siT
Jan 1, 2004 10:42 AM
