20G turbo-t3/t4
20G turbo-t3/t4
is there a big difference between the two? which one is capable of putting down more hp? im guessing the t3/t4 but wat is the 20G capable of? and they're the greddy kit upgrades for the gsr? how much?
Re: 20G turbo-t3/t4 (redteg1)
I think I remember seeing somewheere that the 20G turbo's are good for up to 450 HP.
RedTeg you post gave me an idea, If the Greddy kit for the Lude comes out with a 18G series turbo, I might also buy a 20G series turbo. I think that I would stick the 18G with the CARB E.O number on the car for smog check and the rest of the time I could run a 20G turbo in my car.
New User
Re: 20G turbo-t3/t4 (BoM)
Not really, it would still remain the same size on the housing simply changing the compressor wheel and a little port job at most on the same turbo. Correct me if I'm wrong please?
Re: 20G turbo-t3/t4 (BlueShadow)
yea well im guesing thats wat everybody does either way if they can't or decide against selling their 18G
http://www.dim.com/~mackys/z/mods/upgraded-turbos.html
Re: 20G turbo-t3/t4 (boost killz)
a TD05-18G and TD05-20G have the same exhaust (TD05) but different compressor fan sizes (18,20) but the same compressor housing size (G)
their manufacturer ratings are low but I know for a fact that 20G at about 30 pounds will lay down at least 480HP. They are capable of spinning to 35psi. The T3/T4 make a few ponies more but spool faster. Also the Garret/Turbonetics are readily available in ball bearing (BB) setup whereas I think there is only one company the makes Mitsubishi Heavy Industry ball bearing turbos, the shafts on the Mitsu turbos also aren't as reliable at the limit as their counterparts. I use a BB T4 and max spool is at 2900 rpms. I have no problem burning out 3rd gear at 18 pounds of boost.
faded
07-29-2005 01:10 AM
