CATALYTIC CONVERTER HELP.......QUICK PLEASE :)
Old Feb 3, 2002 | 07:28 PM
intekragsr's Avatar
Default CATALYTIC CONVERTER HELP.......QUICK PLEASE :)
Ok, i can unbolt the cat, but how the hell do I get the o2 sensor off? the sheild thing is too much in the way to use a wrench, and I dont wanna damage the wires. I am under it with jackstands so there not much room to move around.
Ne suggestions?
thanx
Old Feb 3, 2002 | 08:22 PM
DR. ON POINT's Avatar
Banned
Default Re: CATALYTIC CONVERTER HELP.......QUICK PLEASE :) (intekragsr)
get a wrench and take it off...its realy jut like a big bolt......use a lot of wd-40
Old Feb 3, 2002 | 08:51 PM
dustin's Avatar
Default Re: CATALYTIC CONVERTER HELP.......QUICK PLEASE :) (On Point EK)
Take off the cat. If necessary, remove the heat shield.
Dustin
Old Feb 3, 2002 | 09:01 PM
Etylorcen's Avatar
Default Re: CATALYTIC CONVERTER HELP.......QUICK PLEASE :) (dustin)
Yeah disconnect the o2 sensor before trying to remove it from the cat. Take off the cat then once you have it all off then you can take off the o2 sensor at your leisure and you'll have a whole lot more room to work with.
Old Feb 3, 2002 | 09:26 PM
intekragsr's Avatar
Default Re: CATALYTIC CONVERTER HELP.......QUICK PLEASE :) (Etylorcen)
how do i remove the o2 sensor?
Old Feb 3, 2002 | 09:29 PM
threatcon13's Avatar
New User
from what i remember...doesnt it clip in / out?
Old Feb 3, 2002 | 09:30 PM
Farnsrocket's Avatar
unplug it up above.
Old Feb 3, 2002 | 10:04 PM
intekragsr's Avatar
Default Re: CATALYTIC CONVERTER HELP.......QUICK PLEASE :) (Farnsrocket)
haha ok.....ill wait till tommorow when there is more light. thanx
Old Feb 3, 2002 | 10:07 PM
New User
take off the shield/ cat first, then it'll be easy.
Old Feb 4, 2002 | 06:35 AM
dbman96's Avatar
New User
Default Re: CATALYTIC CONVERTER HELP.......QUICK PLEASE :) (turbo01gsr)
There is also a special socket intended for O2 sensors that makes the job a lot easier.
camil212
Jan 17, 2006 10:44 PM
IronQQQ
Aug 27, 2003 08:52 AM
Toda Party
Dec 26, 2001 11:47 AM
Etylorcen
Oct 25, 2001 07:31 AM
R134
Aug 27, 2001 02:08 PM
