Question about EGT's
Old Feb 3, 2002 | 04:56 PM
ElectronVTEC's Avatar
Default Question about EGT's
I'm running about 1450F after a hard pull through 3rd gear, is that too high? Keep in mind i'm at 10.6:1 so I'm just askin. Around town its about 1100F @55MPH in 5th gear. Lower gears its about 800F. This is my first turbo car so I'm a little new. Anyway, its pulling well and so far everything seems ok. Boost is about 5.5 psi, EGT probe is in the #3 runner of the turbo manifold. I don't hear any detonation so far... TIA, EV.
Old Feb 3, 2002 | 06:15 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: Question about EGT's (ElectronVTEC)
when i tuned my car on the dyno at 12.5 to 1 air/fuel ratio,my auto meter gauge would read 1450.
Old Feb 3, 2002 | 06:18 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Question about EGT's (turbotypeR)
That's like 100 degrees higher than my friend told me to run mine. He tuned my setup and he's pretty knowledgeable...for the most part.
However, do a search. There are pretty big differences among what people have gone up to....some say 1500, some say 1250 max. I dunno what to make of it, and I still don't. Hmph.
[Modified by shamoo, 10:19 PM 2/3/2002]
Old Feb 3, 2002 | 07:31 PM
Farnsrocket's Avatar
Default Re: Question about EGT's (shamoo)
I run around 1500F in 5th gear cruising down the highway at 70 or 80.........no problems.....EGT probe in #1 runner 1" from block. B18C1, Drag III, 7psi, 310's, 8:1 Vortech, B&M commando, VAFC
[Modified by Farnsrocket, 8:33 PM 2/3/2002]
Old Feb 3, 2002 | 08:48 PM
shamoo's Avatar
Default Re: Question about EGT's (Farnsrocket)
Wow....the 3rd runner is supposed to be the hottest. 1500 on your #1?? Woah. What does your gauge go up to? Mine only goes up to 1600. You would think that the high end of a gauge is where you want to stay away from.....I guess not with EGT's.
EGT's are so confusing. I guess a sure way is to also have an A/F.
Old Feb 3, 2002 | 09:25 PM
I have a Greddy EGT gauge........it goes up to 1200C............the red line/warning line starts at 900C which would be 1908F!!!!
700C is 1484F and that is where I usually am while on the highway.
Is the #3 runner the hottest???.........I always heard #1 or #3.
I heard someone say the #1 is the furthest from the fuel supply and it would get the least amount of fuel, but wouldn't the electronic controlled fuel injection eliminate that? Anyway, I think I am OK, my a/f gauge shows a good ratio and I have not had any detonation.
blackeg
Engine Management and Tuning
11
Oct 5, 2010 06:53 PM
blackeg
Aug 9, 2010 04:31 PM
blackeg
Dec 18, 2006 03:56 AM
Drew Peacock
Aug 31, 2004 01:08 AM
JFK78
Oct 28, 2001 10:07 AM
