TURBO LS Question
Old Jan 30, 2002 | 05:55 PM
TURBO95's Avatar
Default TURBO LS Question
Hi.I just got my drag 3 kit on for my LS..i got a chip ecu for it,act 6puck,and msd 6al w/coil n wires..what are your guys estimate time my integra LS with that drag 3 kit will hit in the 1/4?what level of boost sould i boost at to be safe?plmk.thanks
Old Jan 30, 2002 | 07:23 PM
JAME CHANOBI's Avatar
Default Re: TURBO LS Question (TURBO95)
5-7psi would be good stock internals. anything over that im not sure
Old Jan 30, 2002 | 07:37 PM
Phantom's Avatar
what kinda chip for your ecu is it? If the chip is meant for a naturally aspirated car you best get rid of that quick
Old Jan 30, 2002 | 07:48 PM
DIRep972's Avatar
Smarter than you
you will be fine with 8psi... I just got my car running good and im running about 6.5psi and it feels soo fast.. Im thinking its high 13's.. what exhaust u got?
Old Jan 30, 2002 | 07:59 PM
TURBO95's Avatar
Default Re: TURBO LS Question (DIRep972)
im running an apexi n1 catback exhaust..and i got a chip ecu for my turbo setup..not N/A..on my ls motor.
Old Jan 30, 2002 | 08:00 PM
TURBO95's Avatar
will a type R mainfold bolt on my ls head and will it work?plmk.thanks
Old Jan 30, 2002 | 08:04 PM
DIRep972's Avatar
Smarter than you
you can MAKE it work, but the skunk2 for the LS is identical and makes the install a breeze..
Old Jan 30, 2002 | 08:31 PM
TURBO95's Avatar
wut do i have to do to make it fit?
Old Jan 30, 2002 | 08:39 PM
boosted hybrid's Avatar
Man...i am boosting 10psi daily on my bone stock LS. Assuming that you tune the motor correctly you should have no problem running 8-10lbs daily driven. Hell i had a friend that had a b20 in his hatch that ran 14lbs daily driven, of course he did have accel dfi standalone and larger injectors and it was tuned. It is all about tuning. But with the drag kit you should be safe at 8lbs...but your fuel pressure is going to be very high. I woud recommend getting a standalone like hondata, haltech, etc and larger injectors, say 440cc, and tune it. You will be much better in the long run.
Old Jan 30, 2002 | 08:40 PM
DIRep972's Avatar
Smarter than you
Im not an expert on it, but if someone knows where the link is to ENDYNS installing a typeR SC on a LS page is thats where u can find instructions on how to do it..
Old Jan 30, 2002 | 09:27 PM
TURBO95's Avatar
can you give me a url link to it.cause i cant seem to find that section..thanks
Old Jan 31, 2002 | 12:01 AM
turbopimp's Avatar
TURBO95,
make sure your chip doesn't advance ignition timing or else you may end up with some nasty cracks in your block... 8 psi should be safe everyday driving
Old Jan 31, 2002 | 04:23 AM
backlash's Avatar
Here you go, check out this link. http://www.theoldone.com/articles/conversion/
Old Jan 31, 2002 | 07:11 AM
DR. ON POINT's Avatar
Banned
ur car should be faster than that...get some larger injeectors, and some fuel stuff......mmmmpsht
Old Jan 31, 2002 | 09:08 AM
Doodoo's Avatar
Default Re: TURBO LS Question (turbopimp)
Also don't raise the rev limit. Especially on stock internals. 7K is plenty with turbo.
Old Jan 31, 2002 | 10:32 AM
dustin's Avatar
Default Re: TURBO LS Question (On Point EK)
No, that's about how fast it should be.
Old Jan 31, 2002 | 10:40 AM
DIRep972's Avatar
Smarter than you
Ive got DSM 450's and hondata in my back seat.. 11psi tuned and ill be plenty fast.. .
Old Jan 31, 2002 | 12:02 PM
Drag III Integra's Avatar
14.4 on stock injecotrs and 6 pds stock exhaust as well. so u can kinda go from there. also no tuning
Old Jan 31, 2002 | 06:34 PM
Ri5e's Avatar
Default Re: TURBO LS Question (Drag III Integra)
13-14 PSI, Bone stock internals, 370 ccs, S-AFC, Bosch inline fuel pump, 93 Octane.
It's been over a year running the setup, no problems whatsoever.
2ndchirp
Mar 15, 2010 04:50 PM
rickturboteg
Jul 17, 2006 03:20 PM
92CivicSIRhb
Sep 27, 2005 05:47 PM
mvbadboy
May 6, 2003 07:30 AM
Darren94ls
Aug 20, 2002 04:14 PM
