How to hook up Aeromotive fuel regulator.
Better than steak
Ive never held one of these in my hand and I wanted to know what size and where the lines go. From looking at it I see a Vaccum source and return line, but the side ports on the side is what gets me. I know one side is used from the fuel rail but what does the other port do and where does it go?
Also, what AN size are each port..
Thanks,
art
Thanks,
art
New User
Re: How to hook up Aeromotive fuel regulator. (Arturbo)
I believe both sides are -10 an and the return is -6 an. One side screws into the end of your fuel rail like you said, the other connects to the fuel line running into the rail. Obviously, you will need to get some fittings for this all to work.
Better than steak
Re: How to hook up Aeromotive fuel regulator. (SilverLudeSi)
I have the fittings so that isnt a problem. But you say one end goes to the other side of the rail but isnt that where the line from the fuel filter goes?
art.
art.
New User
Right, exactly, the line from the fuel filter goes into the fpr.
Like this: fuel filter ---> fuel line ---> fpr ---> fuel rail
Re: How to hook up Aeromotive fuel regulator. (TurboT)
i dont know where u guys learned that that was the way to setup the regulator...
the regulator has 2 inlets on it... which are the 2 bigger holes on the upper portion... from ur fuel rail... of a line coming from it... that connects to one of the holes... the other one gets plugged up... the return is smaller and on the bottom... the little nipple on the side of the reg is for the vaccum... thats about it
Better than steak
Re: How to hook up Aeromotive fuel regulator. (Tom)
thanks tom, I was thinking you would plug it up. I was drawing it out here on paper and the 2nd port made no sense. I was thinking, how can you put the inlets on both sided of the fuel rail.
tom thumb gets the
art
tom thumb gets the
art
I am going to have to get a fuel regulator when I install the turbo in a few weeks here. So do you think the aeromotive would be a good choice? The best choice? ART post pics when you get it put in if you could!!
Better than steak
Re: How to hook up Aeromotive fuel regulator. (SlowB16)
Well if you are running a fmu you can use the stock one. The only reason Im getting an adjustable is because Im going stand alone with larger injectors.
art
art
if u change the injectors ull prolly want to change the regulator... as for me... the regulator is one of the things on top of my list...
how do you change your return line into AN ?
i was looking at how the rubber return hose goes into the small metal fuel lines and i couldnt figure it out..
anybody have pics of their setup ?
Better than steak
Re: How to hook up Aeromotive fuel regulator. (D-SPEED)
art
New User
Better than steak
Fuel filter------>fuel rail--->injector 4---->3---->2---->1---regulator -10 line.
The top port goes to a vaccum source, and the bottom goes to the return line -6 line.
art
art
New User
art
art
sorry for the blurry picture... but u can also put it on the end of the fuel rail as well...
oh... and if anyone interested... i have a str fuel rail with the stock fpr location tapped and plugged as well as -10 fitting on both sides... $60 takes it... (its polished) perfect condition
What about the B&M fpr which I already have,and vortech fmu with stock injectors? SOund good for the time being until I can afford the aeromotive, ditch the fmu and get new injectors?? When you say standalone, does that entail getting some sort of fuel computer (VAFC)?
there is none... see the ss line coming from the underside... basically from the back of the car... i use that... well used... im changing my setup now
New User
the regulator is not too heavy to just hang off the end of the rail ? I have never actually held one in my hands, but it looks quite a bit more bulky than the stock FPR.
also, I assume that if you didnt put it on the end of the rail, you would mount it on the fire wall or strut tower ? having that extra fuel line between the rail and the regulator wont hurt its functionability ?
art, that would be great if you could post some pics up when you get yours going.
