quaife install
Old Feb 1, 2002 | 06:18 AM
jdmciviceg's Avatar
New User
Default quaife install
I just recieved my quaife but there are no instructions for clearances. Does anyone know off hand or does it install just like a ITR lsd? Also do u reuse the stock ring gear or get a new 1. I'm also getting 3rd gear replaced is there anything else that should be replaced liek teh main bearings or anything?
Old Feb 1, 2002 | 06:23 AM
boost killz's Avatar
New User
Default Re: quaife install (jdmciviceg)
Since you have the trann split anyhow might as well change the synchros as well.
Nick
Old Feb 1, 2002 | 07:01 AM
hybrid901's Avatar
Default Re: quaife install (boost killz)
Thats what I wanted to do but when I went to acura I was told that you have to buy the whole gear set so I just bought the 3rd gear set. Anyone know about installing the quaife? I just need to know what to tell the acura tech.
btw I posted under a co-workers name before
Old Feb 1, 2002 | 08:18 AM
Blown90hatcH's Avatar
Default Re: quaife install (hybrid901)
So....you are not installing the Quiafe? You can reuse the stock Ring gear. You will want to get new bearings for it though. You will have to get the Speedo gear removed from the stock diff, or buy a new one. Then have your new bearings pressed on. You will want to check the clearances on tranny to see if you have to reshim it.
Jason
[Modified by Blown90hatcH, 9:39 AM 2/1/2002]
Old Feb 1, 2002 | 09:19 AM
VaporTrail's Avatar
New User
Default Re: quaife install (Blown90hatcH)
Jason
Actually, you can't purchase the speedo gear from the dealer. You have to buy the whole diff. So don't break the speedo gear Make sure you buy new carrier (diff) bearings.
Old Feb 1, 2002 | 11:47 AM
apexii's Avatar
Here's a walkthrough: http://hondaprelude.com/resources/article.asp?id=52
Old Feb 1, 2002 | 10:08 PM
Default Re: quaife install (VaporTrail)
Wow, leave it up to honda to make us buy the entire diff.
Old Feb 1, 2002 | 10:46 PM
InfamousRS's Avatar
ehhhh... Who needs a speedo?
Old Feb 1, 2002 | 10:50 PM
Markaccord95's Avatar
Default Re: quaife install (BLK94RS)
rip the tranny apart, take the final drive gear off, add new diff bearings, put it back in place, seal the tranny, add fluid
Old Feb 1, 2002 | 10:56 PM
InfamousRS's Avatar
Default Re: quaife install (Markaccord95)
I just read through the artical on hondaprelude.com. That seems like a very hard instal. Is it anything that a "normal" person should attempt? How much would it cost to have it instaled?
Old Feb 1, 2002 | 10:57 PM
about $100 from a good source
Old Feb 2, 2002 | 11:25 AM
InfamousRS's Avatar
Only $100 to have instaled??? Screw doing it my self, I'll have it done. Im afraid of my tranny.
paopao
Transmission & Drivetrain
Jun 14, 2010 10:40 AM
WVTURBOCRX
Aug 25, 2007 10:13 PM
Shmaa
May 24, 2005 12:52 AM
Wes V
Oct 25, 2003 07:37 AM
