whats the flow rate in cc's on these injectors?
d16 stock injectors = ?
b16 stock injectors = ?
b18 stock injectors =?
thanks in advance
MARLON
thanks in advance
MARLON
Re: whats the flow rate in cc's on these injectors? (Sonny)
i just called honda, and they have different part numbers on the injectors between the series of engines.....he said the ARE NOT the same flow rate, but the system dosnt give him such detailed specs, but that indeed that are not the same.
come on guys
come on guys
Re: whats the flow rate in cc's on these injectors? (SolidSpruce)
Trust us...they all have the same flow <U>rating</U>. They will flow differently in each respective vehicle due to different factory fuel pressure settings.
They have different part numbers because they are different parts given the model year. OBD-0, OBD-1, OBD-2...and there are some physical differences as well. Some use thicker or thinner seals at the manifold.
....but they all flow at 240cc/min at 43.5psi fuel pressure.
[Modified by DSF, 2:14 PM 7/10/2002]
Re: whats the flow rate in cc's on these injectors? (technine)
anyone know the flow rate of non turbo eclipse/talon injectors?
Re: whats the flow rate in cc's on these injectors? (DSF)
VEHICLE Injector Types Flow Rate
1988-91 Civic si/crx si Peak and hold 240cc
1992-95 Civic si/ex Saturated 240cc
1996-00 Civic Saturated 240cc
1990-91 Integra Peak and hold 240cc
1992-00 Integra ls/gsr/type R Saturated 240cc
1992-96 Prelude non-vtec Peak and hold 240cc
1992-96 Prelude VTEC Peak and hold 345cc
1997-up Prelude VTEC Saturated 280cc
1991-up Sentra se-r/200sx se-r Saturated 265cc
1991-up MR2 Turbo Peak and hold 440cc
1988-91 Supra Turbo Peak and hold 550cc
1993-up Supra non -Turbo Saturated 315cc
1993-up Supra Twin Turbo Peak and hold 550cc
2000-up Celica GT-S Saturated 310cc
1990-up Miata 1.6 liter Saturated 215cc
1993-up Miata 1.8 liter Saturated 240cc
1993-up RX-7 Twin Turbo Saturated 550cc/850cc
1990-96 300zx Twin Turbo Saturated 370cc
1991-up 3000GT VR-4 Peak and hold 350cc
1989-up Eclipse Turbo Peak and hold 450cc
darthure
01-28-2007 03:04 PM
