Cooling for a b16 with place racing mounts with a big t3/t4 turbo
I really need to some input on how to cool my car with this setup. I have absolutly no room for a fan. I have a del sol dual core radiator and it works fine until the tempature outside rises up past 85 degrees and then it starts to run hot since I have no fan and no room for one. Is anybody running this setup or does anyone have any suggestions.
Lee
Lee
Re: Cooling for a b16 with place racing mounts with a big t3/t4 turbo (Rex2nv)
So would I need to get a pusher or puller fan, and will a 6in fan be fine, I really only plan to run close to 300 hp eventually.
Lee
Lee
do you have no room for your factory fan or no room for a fan at all? you can buy a slim fan and put it in place of your factory one.
Re: Cooling for a b16 with place racing mounts with a big t3/t4 turbo (CovertFI)
I have no room at all, my turbo sits like 1 to 1 1/2" from the radiator. It sucks cause there really is no room.
Lee
Lee
get a larger 12inch slimline pusher fan from autozone its pretty cheap cost like 45 bucks.. works well. make sure you wire it to push air in rather than pull
[Modified by b18bturbo, 11:42 AM 7/8/2002]
Re: Cooling for a b16 with place racing mounts with a big t3/t4 turbo (b18bturbo)
and dont use the little zip ties that come with the fan kit. they will rip throught the fins in the radiator.
Thanks alot guys, I will try that today hopefully it will fix my problem.
Lee
Lee
I run something VERY similar to you, hope this pics helps
Thats a slim-line fan like what they've been talking about.
[Modified by Speed PHreak, 6:30 PM 7/8/2002]
Re: Cooling for a b16 with place racing mounts with a big t3/t4 turbo (Speed PHreak)
Yeah thats pretty close, but I don't have any room at all, I guess I will go from the other side.
Lee
Lee
