HELP asap! how'd you guys get the bolt in for the drag manifolds?
all the bolts go into the manifold fine, but the bottom center one is really close to the tubes on the manifold, and i cant get the bolt through to bolt down the manifold. what did you guys do?
Re: HELP asap! how'd you guys get the bolt in for the drag manifolds? (ceemarun)
You unbolt everything. Then you act like you are putting the manifold on but before the stud goes through the manifold completely, you place the nut and hold it there. Then slightly push and thread and you will start to thread the nut on the stud. Keep moving closer and thread the nut at the same time.
Assuming you removed the stud from the far left and placed it in the middle.
Good Luck and play with it a little you'll know what I'm trying to describe.
Re: HELP asap! how'd you guys get the bolt in for the drag manifolds? (iloveracing)
New User
Re: HELP asap! how'd you guys get the bolt in for the drag manifolds? (GSRgrrl)
I actually shaved the bolt's head a little to get it to fit.
thats what i had to do w/ my fmax mani....3 of the top ones
Re: HELP asap! how'd you guys get the bolt in for the drag manifolds? (94goldjungsr)
the old heads had all studs + nuts
the new heads have 2 outer studs and the rest are bolts
If I were you, I'd replace all those dumb bolts with studs, makes things 10x easier
Re: HELP asap! how'd you guys get the bolt in for the drag manifolds? (dustin)
i guess i'll pick some up tomorrow. do you know what size the studs should be? (? threads/in), etc? thanks.
