t-25 -can you answer??????
Old Jul 10, 2002 | 05:23 PM
4gvtec's Avatar
Default t-25 -can you answer??????
my friend has a gsx and the turbo took a ****.its a t25.luckly i had an extra t25 laying around.after we swapped them out we noticed that the new t-25 spooled at 3500 till redline.the old t-25 spooled at 3100 at took a **** at like 6000.the numbers on the original t-25 said ar /48 m10 w/l and the one i gave him said ar/48 m24 on the compressor housing.
can anyone figure this out?
no! it is not a figment of my imagination this t25 is different.
how do i know?
because i have drove this car many,many many times. thanks.
Old Jul 10, 2002 | 05:29 PM
93LSivic's Avatar
Default Re: t-25 -can you answer?????? (4gvtec)
The latter years dsm's came with a larger trim t25. I believe it was a t28.
Old Jul 10, 2002 | 05:33 PM
civictypenos's Avatar
is there a chance that one of the turbos was from a automaticmi know the turbos on the automatics where different then the 5 speeds.
Old Jul 10, 2002 | 05:35 PM
93LSivic's Avatar
Default Re: t-25 -can you answer?????? (civictypenos)
Only on the 1st gens I believe. I think the 2nd gens had the same turbo's. I think mitsubishi went with the t28 around the 1998 model year.
Finest's Avatar
Default Re: t-25 -can you answer?????? (93LSivic)
Uh, NO. They all came with the t-2small. No difference in trim or anything.
Maybe you got a 14B?
4gvtec's Avatar
his is a 98 gsx.i dont know what year mine was out of but it was a 2nd gen.you can tell a difference between the two though.
Old Jul 10, 2002 | 05:36 PM
Finest's Avatar
Yes, only on the 1G's. But all 2G's had the same turbo.
Old Jul 10, 2002 | 05:38 PM
Finest's Avatar
Get a pic of the two.
4gvtec's Avatar
it was the same fit.i changed it myself,every thing is the same.just the #s are different.one off his was ar.48 m10 mine was ar.48 m24 i dont know what they mean but you can feeeeeeeeelllllll a difference.
thanks for the replies there!
Old Jul 10, 2002 | 05:41 PM
93LSivic's Avatar
Default Re: t-25 -can you answer?????? (Prelude_RCR)
I am almost 100% positive that dsm changed their t25 lineup for the 95+ turbo's sometime in the late 90's.
A friend bought a 95 gsx brand new with extended warranty. The stock turbo blew itself 2 pieces in 1998. He brought it to the dealership and was told that the turbo is no longer available for that model year gsx, and that he will have to get a turbo from the current year eclipse.
It was a different turbo. Larger. Spooled later. Made more power.
[Modified by 93LSivic, 9:41 PM 7/10/2002]
maybe the charge ppipe was loose and when you put the new one on you tightened it up,where did you get the turbo from,maybe it was a hopped up version and you didnt know it??
Old Jul 10, 2002 | 05:47 PM
4gvtec's Avatar
no it was tight.
dnbruut
Sep 9, 2005 07:49 AM
TURBO DC2
Mar 28, 2005 07:25 PM
mrbsponge
Jul 21, 2004 06:01 PM
batboyvaj
Apr 8, 2002 07:06 PM
