Help with Oil Feed Fittings
I just upgraded from my IHI RHB52 Turbo to a TD05-18G but now my oil feed line has the wrong fitting. The oil feed line has a flare that curves out and so does the TD05. So I need to know if I can get an adapter or if I need to get a new oil feed line. If I need an oil feed line what is the name of the fitting that will fit the TD05? I didn't put the IHI on my car so I don't know anything about oil feed line except it is braided steel and the threads are the same size for both the IHI and TD05...
Any help is much appreciated....
Re: Help with Oil Feed Fittings (reXem)
Oh another problem (kinda) is now my oil return line has to make a serious S-Curve to make back the pan. I kinda rigged up one for temporary use but I want to make one for permanent use. What I did was create the S using two right angle copper pipe pieces but they don't have very much for the gear clamp to grab on to so I don't know how long it will hold. It may hold forever but I just don't want to risk it. SO my question is there a material for Oil Return that can make tight turns without kinking? or should I just remake my line using proper right angle fitting?
http://www.magnumforceracing.com/ear...m_adapters.asp
can you take a pic. i dont see how you cant make it work.
edit: for the size problem take it to your local hardware store they should have templets so you can find the size
[Modified by CovertFI, 9:29 AM 7/8/2002]
pcguy760
07-15-2008 07:12 PM
