wastegate still messed up
ok after adjusting the allen bolt on the deltagate it still wont boost past 4 psi wut the hell we turned it 1 and a half turns and it didnt do anything at all...with the vacume off it will boost so wuts the problem here i was told by a friend not to hook the vacume up to the manifold and the diaphram in the wg is fine no cracks or tears
Re: wastegate still messed up (jdmB18hatch)
sounds like a 5psi spring (is it?), take off the nut and screw the allen head bolt till its just about flush wiht the wastegate housing, see if you boost properly then...
[Modified by GudeH23a, 1:19 AM 7/9/2002]
yes, its a 7psi spring. take off the nut and screw the allen head bolt till its just about flush with the wastegate housing, maybe leave 1 thread left poking out. let us know what happens...
well after turning it like 2 turns it boosted at 5 psi and i just took the nut off and turned it again and were about to take it down the road again but the bolt feels really loose in there
Re: wastegate still messed up (CDooMe2)
no leaks at all we can disconect the vacume from the WG and itll spike we took it down the road just now and hit just about 6 psi...the gauge is also fine vacume at idle is -20 the adjuster is almost all teh way in is it possible to buy a 9 lb spring?
AlphaKennyWun
02-12-2002 04:26 PM
