What exactly is this??? (pic)
Old Jul 8, 2002 | 04:24 PM
legendboy's Avatar
Default What exactly is this??? (pic)
I'm not sure exactly what this pipe does and I want to eliminate it completely.
Old Jul 8, 2002 | 04:30 PM
sushibug's Avatar
Default Re: What exactly is this??? (legendboy)
that bar is connected to either the wastegate or actuator thingie... its either for fitment issues or required for boost spiking/bleeding. educated guess cuz i have no clue... just tryin to help.
Old Jul 8, 2002 | 04:40 PM
G2turbo_terror's Avatar
Default Re: What exactly is this??? (sushibug)
If you know what car it came off of just go to the public library and look at the service manuel and it'll tell ya, unless some one else can answer this sooner. You could use the bung to mount an egt probe if you remove it.
[Modified by G2turbo_terror, 1:42 AM 7/9/2002]
Old Jul 8, 2002 | 05:58 PM
legendboy's Avatar
Default Re: What exactly is this??? (G2turbo_terror)
Good Idea
Old Jul 8, 2002 | 10:00 PM
AbaZ's Avatar
I could be wrong, but it looks more like a EGR setup than a wastegate.
If it is a EGR setup, you can simply just plug it off. Where is the wastegate at?
Its obviously internally, but I dont see the actuator anywhere. did you take it off?
Jeff
Old Jul 8, 2002 | 11:22 PM
DLB1994's Avatar
Default Re: What exactly is this??? (AbaZ)
EGR valve
killacam661
Jan 17, 2009 06:58 AM
elpiar
Sep 8, 2005 09:32 PM
SOHC_MShue
May 8, 2005 09:35 PM
KiNG $h!t
Feb 10, 2005 06:02 PM
GSRswapandslow.
May 1, 2004 07:21 AM
