crankshaft question
Old Jul 10, 2002 | 09:56 AM
thejdmkid's Avatar
Default crankshaft question
i got a 95 ls block from darton sleeved, all the good stuff. it came with the main caps, just no crankshaft, i'm gonna go buy one from acura. will there be any problem fitting it in the block? will a machine shop have to machine it in to fit....?
Old Jul 10, 2002 | 10:54 AM
dustin's Avatar
Default Re: crankshaft question (thejdmkid)
No but you will need bearings that match both the block main bores and crank journals.
Also, you are going to get raped if you buy an LS crank from the dealer. You should just buy a relatively new one off someone, and have it micropolished.
Old Jul 10, 2002 | 11:04 AM
Adi Radoncic's Avatar
On Fire!
Check out http://www.honda-performance.com/pricelist.html
and see if they sell cranks that have already been micropolished and balanced for your application....
Adi
Old Jul 10, 2002 | 11:36 AM
DLB1994's Avatar
cheaper to just find u a used b18a crank or bottom end
Old Jul 10, 2002 | 11:59 AM
93LSivic's Avatar
Or you could always buy the eagle crank. 800 some dollars they are.
Old Jul 10, 2002 | 12:00 PM
b18bturbo's Avatar
Default Re: crankshaft question (93LSivic)
i have ls crank if you are needing it .
vtechachey
Mar 4, 2008 08:52 PM
Pandahatch
28
Feb 27, 2006 08:08 PM
Pandahatch
Feb 26, 2006 10:08 AM
wantboost
Jul 17, 2004 08:44 AM
Jared
Jun 24, 2001 09:53 AM
