Clocked my turbo...shaft play?
1 Post
I just clocked my turbo...im little concerned because before i clocked it, there was no shaft play at all. Now there is shaft play- 10 thousands of an inch. I used this special tool to measure the play.
How concerned should i be about this? the shaft doesnt touch the compresor housing. The turbo was brand new and never used.
thanks for any help.
Marc
Edit: i get more movement on the comp side compared to the exhaust.
[Modified by Cramerox, 4:56 PM 7/10/2002]
Marc
Re: Clocked my turbo...shaft play? (Cramerox)
mine moved a little to and once you add oil in there, the play should be even less ... as long as it doesn't touch the housing it should be fine.
1 Post
Re: Clocked my turbo...shaft play? (Trigun)
sounds good..it was just a little upsetting- i tried to do it carefully with loosenign the bolts as little as possible. did u torque your to a certain foot pounds?
btw did ur drag kit come witha missing link? i need to buy one.
i didn't torque it to a certain spec ... i just made sure it was "adequately" tight.
i didn't get a missing link with my kit or any check valves.
[Modified by Trigun, 5:14 PM 7/10/2002]
R6E6I6D
08-23-2005 10:50 PM
