lots of boost lag
Old Jul 7, 2002 | 11:11 PM
Mr. Softee's Avatar
Default lots of boost lag
hm... im getting a ton of boost lag. I'm not seeing full spool up until about 5.5k rpms or so... this is with a basic 50 trim .63a/r t3/t4 GSR drag turbo...
any idea why this is happening? I know it should be spooling much faster.
Old Jul 8, 2002 | 12:19 AM
ninesecrx's Avatar
Default Re: lots of boost lag (94goldjungsr)
if you dont have a boost controler...put one on. It will keep the spring closed until u hit desired boost. A wastegate opens a little before it hits boost so it can regulate before the spring fully opens. Maybe you have a boost leak as well.....check that out......Mike
Old Jul 8, 2002 | 12:26 AM
Flamenco-T's Avatar
Default Re: lots of boost lag (ninesecrx)
yes, I agree, with no EBC, my WG started to open up at 4 psi when the WG spring is set at .45 bar...
with the EBC, the WG stay shut until the desired boost...
Old Jul 8, 2002 | 12:35 AM
b18bvudoo's Avatar
New User
Default Re: lots of boost lag (Flamenco-NA)
yeah, but 5500 is kinda high
Old Jul 8, 2002 | 01:45 AM
TurboR1391's Avatar
Default Re: lots of boost lag (b18bvudoo)
With 9:0:1 compression pistons in my car I don't get full boost until 5500rpm.
Old Jul 8, 2002 | 01:52 AM
Mr. Softee's Avatar
Default Re: lots of boost lag (Vonte')
i am running off the wastegate... im going to take your advice and get a manual boost controller.
peace
sam
Old Jul 8, 2002 | 05:51 AM
CovertFI's Avatar
i have about the same turbo using the wg. it starts to spool at 3k and finishes at 4k. 5.5k is way too high. i am only boosting 5psi but the time it takes to go from 1psi to 5psi is less than a sec. check your lines. where is your wg getting the boost signal from?
Old Jul 8, 2002 | 06:29 AM
DRAGLS's Avatar
What exhaust wheel do u have stage I,II,III,IV Drag f--ks up sometimes My friend got a dragIII and the exhaust wheel was a stage I spool up was instant on my kit it came w/ a stage III i don't see full boost till around 5200 both GSR
Old Jul 8, 2002 | 06:31 AM
CovertFI's Avatar
Default Re: lots of boost lag (DRAGLS)
i bought mine used. i am guessing it is a stage 3
edit: fitting a 3inch dp to the outlet flange would be near impossible. if that helps
[Modified by CovertFI, 9:32 AM 7/8/2002]
Old Jul 8, 2002 | 06:54 AM
done's Avatar
isnt that good??? due it gives you time to get traction??
WH0R3nEF9
Sep 28, 2005 07:13 PM
turbo95eg6
Jun 12, 2005 12:15 PM
FUP23
Sep 30, 2002 09:15 PM
Snafu-Si
Mar 5, 2002 02:07 AM
Cyrio
Dec 4, 2001 07:00 PM
