tips on setting profec b....
Old Jul 8, 2002 | 03:48 PM
uneekcrx's Avatar
Default tips on setting profec b....
i am having trouble setting this thing and i've read the instructions from greddy but i still need some help.....how sensitive are the ***** on the boost controller? where do you guys have the balance **** .....have any of you guys had any wierd problems with the unit
Old Jul 8, 2002 | 06:53 PM
uneekcrx's Avatar
Default Re: tips on setting profec b.... (uneekcrx)
does anyone own one?
Old Jul 8, 2002 | 06:59 PM
b18bturbo's Avatar
wow.. this is one of the easiest units to install and run make sure first you have the correct dip switches set for internal or external wg. Second turn the first *** in the middle second *** all the way to the left and third *** all the way left. Now boost you should get your wg spring setting.
THen slowly up the low boost to your desiered low boost. Then set your overtake boost aka high boost to what ever bosot level you want on high and walla you done.
Old Jul 8, 2002 | 07:45 PM
uneekcrx's Avatar
Default Re: tips on setting profec b.... (b18bturbo)
i tried that....but in high boost i can only get it to boost to 8psi on the interstate only...(that's with the **** @ around 1o'clock)my friend told me that he could hit 10psi on his same set-up in 3rd.... how sensitive are the hi-low boost *****?
my setup is a zc motor with a 92-95 greddy kit
Old Jul 9, 2002 | 01:20 PM
uneekcrx's Avatar
Old Jul 11, 2002 | 01:07 PM
uneekcrx's Avatar
ttt
Old Jul 11, 2002 | 02:04 PM
niedejb's Avatar
I had that problem when I used both ports on the wastegate. The set up now is compressor->in, out->side of wastegate.
Old Jul 11, 2002 | 02:44 PM
uneekcrx's Avatar
Default Re: tips on setting profec b.... (niedejb)
i have an internal wastegate though just one port
kaptn krunch
May 25, 2008 08:58 AM
all go teg
Aug 5, 2005 04:56 AM
metal-x
Jul 18, 2005 08:08 AM
nigel
Mar 24, 2004 05:29 PM
