am i safe w/o an intercooler?
Old Jul 10, 2002 | 10:42 AM
civicmark's Avatar
Default am i safe w/o an intercooler?
what are the bad sides of this? I've heard what you dont need one, if you're not running too much boost? how much is to much to run with out the intercooler?
thanks
~~homemade turbo in the making~~
edit: also, i've heard something about spraying water/alcohol to cool it down......?
[Modified by civicmark, 7:58 PM 7/10/2002]
Old Jul 10, 2002 | 10:46 AM
inspyral's Avatar
Default Re: am i safe w/o an intercooler? (civicmark)
I wouldn't run more than 4-5lbs of boost non-intercooled.
I/C's lower the temperature of the intake charge and decrease the chance of detonation, which lets you run more boost.
Old Jul 10, 2002 | 10:53 AM
DSF's Avatar
DSF
I was running 8.5psi non-intercooled for a short while. I don't recommend it at all. Feel your charge pipe after a heavily boosted run and you'll understand why. I concur, 4-5psi sounds reasonable. But with all the factory intercoolers floating around for cheap, I see no reason to run without one.
Old Jul 10, 2002 | 11:01 AM
civicmark's Avatar
Default Re: am i safe w/o an intercooler? (DSF)
the only reason i would run without one is this:
Right now i have my stock d15 in there, and it'll be about 2 months before i get my b18c1 swap in there, so for now, i just want to experiment with only running 4-5 lbs, on my homemade turbo.
Once i get the b18 in there i'll re-do the entire kit.
thanks though, and now, back to that water/alcohol cooling thing......?
Old Jul 10, 2002 | 11:02 AM
inspyral's Avatar
A water injection kit is going to cost about the same amount as an i/c...
Old Jul 10, 2002 | 11:04 AM
civicmark's Avatar
Default Re: am i safe w/o an intercooler? (inspyral)
can you tell me how they work? Is this something that i could make myself? I've got a friend that ghetto hooked his windshield wiper fluid(put water in it though) to spray his i\c......
Old Jul 10, 2002 | 11:57 AM
Turbo Laser's Avatar
Just get a junkyard intercooler for like 25 bucks and rig it up....it's worth it.
Old Jul 10, 2002 | 12:30 PM
B-Series Sol's Avatar
yeah, would that work to spray the intercooler w/ water from the wiper sprayers? Or is there a better way to do that? Sounds like an idea... a goofy one, but still its an idea
Old Jul 10, 2002 | 12:48 PM
civicmark's Avatar
Default Re: am i safe w/o an intercooler? (B-Series Sol)
well, yes it does work, and i've seen it in action. He even bought a nitrous switch to turn it on/off. Both him and I are big on DIY stuff
AND NOW BACK TO MY ORIGIONAL QUESTION:
how does the water/alcohol cooler work!!!!????
Old Jul 10, 2002 | 12:56 PM
CovertFI's Avatar
no ic bad idea? what about some of the pro racers?
the larger the turbo the cooler the air will be at high rpm's.
Old Jul 10, 2002 | 01:15 PM
internet ay's Avatar
Default Re: am i safe w/o an intercooler? (CovertFI)
does stephs car and eds car runing methanol have anything to do with their lack of intercooler?
[Modified by internet ay, 5:23 PM 7/10/2002]
Old Jul 10, 2002 | 01:23 PM
CovertFI's Avatar
Default Re: am i safe w/o an intercooler? (internet ay)
i would not doubt it. does that make a diffrence?
Old Jul 12, 2002 | 05:53 PM
does anyone know the answer to this?
Old Jul 12, 2002 | 06:41 PM
BoostinDC2's Avatar
methanol makes the car run cooler that is why they dont run intercoolers. my friend has an all motor car and he is running meth and 5 mins after a hard pass you can put your hand right on the header and its cold
SOHC50shot
18
Mar 19, 2004 10:49 AM
SOHC_MShue
Mar 21, 2003 01:50 PM
legendboy
Oct 1, 2002 05:51 AM
Duck Sauce
Nov 26, 2001 02:43 PM
Arturbo
Nov 17, 2001 05:15 AM
