egt or a/f gauge? pleae help!
i know this topic's been covered before but i'm getting alot of mixed opinions and pretty much lost now. since i'm a noobie and don't know all that much about tuning, i figured a/f guages will be easier for me to read(and better looking w/ all the lights and everything ) but i'm told a egt is much more reliable/accurate. i thought about autometer a/f and i heard they suck, just like the egt/pyrometer. can you guys give me gauge parts list that wont break the bank and be able to monitor my engine pretty well hopefully under 2 mr. ben franklins?
Re: egt or a/f gauge? pleae help! (theory48)
If you aren't willing to spend money on a good AF meter your best bet would be to get an EGT. The combo of a GOOD A/F meter and EGT is unmatchable. A A/F meter that does not have it's own heated, wide band sensor and signal amplifier/heater control circuitry is nothing more than an idiot light.
Re: egt or a/f gauge? pleae help! (Dee)
i emailed halmeter.com and they told me that the new meters will work w/ the stock sensor? should i still get one from them? also, i'm not planning on doin my own tuning so what can i use just get by in monitoring what's goin on under the hood. also, do you think i should go w/ hondata2b or the vafc hack? i know hondata is better but i figure if i get the msd 6btm and vafc, i would be able to install it myself and be more of a learning experience. what do you guys think?
btw, how are blitz egt gauges? are they reliable/accurate? here is a pix of the one i'm considering on buying
http://photos.yahoo.com/bc/theory48/...c=ph%26.view=t
you know what i ahve no idea either, how can you tell if your running lean or rich based on a pyrometer? lean= hot, rich=cold? Can some one set me sraight?
thanks all
Rob
thanks all
Rob
Re: egt or a/f gauge? pleae help! (rjardy)
thanks all
Rob
thanks all
Rob
Re: egt or a/f gauge? pleae help! (X2BOARD)
Sometimes overly rich conditions cause high ex temps and this condition can only be identified with a AF meter/EGT combo (or a good datalogger).
