Uberdata 1.66 or 1.7?
Old Nov 12, 2004 | 11:57 AM
BDTURBO's Avatar
Default Uberdata 1.66 or 1.7?
Im still trying to go Uber..just wondering what was different about the 1.66 and 1.7? What do you guys like better any why? It says 1.7 (experimental) doe this mean some of the features do not work? Thanks guys.
Old Nov 12, 2004 | 12:00 PM
SOHC_MShue's Avatar
Default Re: Uberdata 1.66 or 1.7? (BDTURBO)
look for the newest release of 1.7. It is working fine now and from what i know has very many fixed bugs. It also has datalogging and some cool stuff like the iacv slider if you are having idle problems. Runs fine in my car
Old Nov 12, 2004 | 12:06 PM
BDTURBO's Avatar
Default Re: Uberdata 1.66 or 1.7? (SOHC_MShue)
ok...thanks
Old Nov 12, 2004 | 12:30 PM
fbp-em1's Avatar
1.7 runs fine in my car and datalogging is nice to have.
Old Nov 12, 2004 | 12:36 PM
Freemantle's Avatar
Default Re: Uberdata 1.66 or 1.7? (fbp-em1)
get 1.7"b" if you need the stockls.bin to work. It's halfway through the announcement thread.
Old Nov 12, 2004 | 12:43 PM
BDTURBO's Avatar
Default Re: Uberdata 1.66 or 1.7? (Freemantle)
ok!
Old Nov 12, 2004 | 12:46 PM
ComputerJLT's Avatar
http://www.ecimulti.org/uberdata
http://www.ecimulti.org/uberdata/forums
check out the fourms;
they change versions every other time i blink. i'm using A version of 1.70 but i know its not the most current.
Old Nov 13, 2004 | 08:49 AM
BDTURBO's Avatar
Default Re: Uberdata 1.66 or 1.7? (ComputerJLT)
sounds good!
Old Nov 13, 2004 | 09:17 AM
hondaguyef's Avatar
I like 1.66. I have never had any problems w/ it and it has all of the features I need.
Phil
Old Nov 13, 2004 | 09:37 AM
AspectIndustries's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComputerJLT &raquo;</TD></TR><TR><TD CLASS="quote"> http://www.ecimulti.org/uberdata/forums </TD></TR></TABLE>
Its http://www.ecimulti.org/uberdata/forum/ No s. -=P
Old Nov 13, 2004 | 01:06 PM
Default Re: Uberdata 1.66 or 1.7? (synik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by synik &raquo;</TD></TR><TR><TD CLASS="quote">
Its http://www.ecimulti.org/uberdata/forum/ No s. -=P</TD></TR></TABLE>
oops
Old Nov 13, 2004 | 01:43 PM
nonvtecD's Avatar
I enjoy 1.66, even though it gives me weird error messages.
Old Nov 13, 2004 | 01:48 PM
Kowalski's Avatar
Default Re: (D15B7turbo)
I'm using 1.7 and it works great. Datalogging
PM me if you need help setting it up.
Old Nov 13, 2004 | 02:27 PM
FragSyndrome's Avatar
1.7 has a much smoother transition between being on and off throttle. Use the 1.7
Old Nov 13, 2004 | 02:49 PM
Default Re: (FragSyndrome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FragSyndrome &raquo;</TD></TR><TR><TD CLASS="quote">1.7 has a much smoother transition between being on and off throttle. Use the 1.7</TD></TR></TABLE>
thats 99.5% tuning right there;
Old Nov 13, 2004 | 03:10 PM
toolowsol's Avatar
Default Re: (ComputerJLT)
1.7 is the way to go, I just finished writing the boost step retard script and it will hopefully be in the next official release, if you really want that feature you can download it from the test scripts forum and replace the boost.als.txt with it.
Old Nov 13, 2004 | 03:33 PM
hondaguyef's Avatar
Please explain.
Phil
Old Nov 13, 2004 | 04:18 PM
mrbsponge's Avatar
so what part of the site can you find the 1.7 stable version all i see is experimental?
Old Nov 14, 2004 | 02:28 AM
T-RO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComputerJLT &raquo;</TD></TR><TR><TD CLASS="quote">http://www.ecimulti.org/uberdata
they change versions every other time i blink. i'm using A version of 1.70 but i know its not the most current.</TD></TR></TABLE>
I've heard good stuff about ver 1.70 but havent been able to find it for download
Old Nov 14, 2004 | 07:45 AM
Kowalski's Avatar
Default Re: Uberdata 1.66 or 1.7? (T-RO)
http://www.pgmfi.org/twiki/bin...Tools
Old Nov 14, 2004 | 08:27 AM
93turbo16's Avatar
I like 1.7 for the datalogging. Also the ignition retard is right in that version, it isn't right in 1.66, it retards to much in 1.66.
Old Nov 15, 2004 | 07:12 PM
Default Re: (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">Please explain.
Phil</TD></TR></TABLE>
certainly - I was running 1.66 in my car for a while and when I let go of the gas, my car would jolt - when I pressed the gas again, it would jolt. So basically, if I was cruising on the highway and barely pressing the gas, the car would start shaking a bit if I used too little gas.
Then when I got 1.7, I copied and pasted the EXACT map over to 1.7 - and guess what? - it drives like a dream now - 100% smooth. I think there was some kinda glitch with 1.66 that was fixed in 1.7 for that.
Old Nov 15, 2004 | 07:17 PM
oxSLEEPERxo's Avatar
is there still bugs on the 1.7?
Modified by oxSLEEPERxo at 11:43 PM 11/15/2004
Old Nov 15, 2004 | 08:24 PM
Default Re: (oxSLEEPERxo)
there's always going to be bugs.
but 1.70 is a beter version than 1.7.
and that jolting is tuning; i promise you. you probably were just running some basemap and or your part throttle tuning left something to be desired.
smooth running motors are 99% about tuning with uberdata.
Old Nov 15, 2004 | 08:41 PM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComputerJLT &raquo;</TD></TR><TR><TD CLASS="quote">and that jolting is tuning; i promise you. </TD></TR></TABLE>
On the other hand, it could have something to do with injector cut activating at 5% throttle instead of 0%, which was fixed in either 1.7 or 1.70.
Despite the claims on the front page about sanely labelling UD releases, there is a lot of confusion in re 1.7 and 1.70, also called "B." If you go to the Official Release Forum on the UD Forums, it (1.70 aka B) is the only thread there.
