Should i use ARP headstuds with 1bar of boost?
Old Nov 12, 2004 | 02:54 PM
steve0unce's Avatar
Default Should i use ARP headstuds with 1bar of boost?
i recently did a y7/y8 mini me and and plan to boost 1bar...we changed the hg to a greddy 2mm metal hg (dont know what the compression is)..my friend said that the stock headbolts would be able to hold up...but i am getting funny feelings that it wont...think i should put in arp headstuds? and if so i dont understand the double nut trick...
Old Nov 12, 2004 | 03:03 PM
SOHC_MShue's Avatar
Default Re: Should i use ARP headstuds with 1bar of boost? (steve0unce)
i doubt it will hold up. My headgasket on my y8 won't even hold up at 10psi with arp studs...
Old Nov 12, 2004 | 03:04 PM
SOHC_MShue's Avatar
Default Re: Should i use ARP headstuds with 1bar of boost? (SOHC_MShue)
this is probably what would happen https://honda-tech.com/zerothread?id=1050985
Old Nov 12, 2004 | 03:10 PM
steve0unce's Avatar
yikes...hmmm well i guess i will put the headstuds in just in case...but this is my mess around block...while the other one is gettin darton sleeves
Old Nov 12, 2004 | 03:12 PM
SOHC_MShue's Avatar
Default Re: (steve0unce)
well if its your mess around block and you think it will last until you get the new block in then you may want to wait, but its probably not gonna last long at all on 1 bar
steve0unce's Avatar
haha word...what turbo were you using for 10psi?
Ahknodd
Feb 22, 2009 05:57 PM
Dasfinc
10
Sep 27, 2007 10:37 AM
Firstoost
May 18, 2006 12:23 PM
EK k kay
Sep 7, 2005 10:15 AM
6thgen4u2nv
Apr 22, 2004 06:34 PM
