NGK Users - BCP or BKR?
Old Nov 9, 2004 | 02:23 AM
1SlowSi's Avatar
Default NGK Users - BCP or BKR?
Ive seen too many answers on the two plugs. I have a b16a2, and im gonna be running 300whp around 12psi. Now im sure that either the BCP7E or the BKR7E's will work, but which would actually be better? And are all the new ones BXX7E-11? pregapped plugs. Or can you get ones without the 11. As far as gap goes for my setup here, .030-.032 be good to go? thanks
Forgot to add, will these plugs be too cold for 6-7psi daily? Maybe the 6's will be better for 6-12psi (240-300whp)? Lemme know what you guys think.
Modified by 1SlowSi at 11:36 AM 11/9/2004
Old Nov 9, 2004 | 06:04 AM
whp
Guest
Posts: n/a
Default Re: NGK Users - BCP or BKR? (1SlowSi)
if i make 350whp on 12psi daily, and make a lil over 500whp on c16, is it ok if i just run bkr8's for both street and track? and what gap should i use? 25-26?
Old Nov 9, 2004 | 06:11 AM
00ITR #543's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowSi &raquo;</TD></TR><TR><TD CLASS="quote">Ive seen too many answers on the two plugs. I have a b16a2, and im gonna be running 300whp around 12psi. Now im sure that either the BCP7E or the BKR7E's will work, but which would actually be better? And are all the new ones BXX7E-11? pregapped plugs. Or can you get ones without the 11. As far as gap goes for my setup here, .030-.032 be good to go? thanks
Modified by 1SlowSi at 11:36 AM 11/9/2004</TD></TR></TABLE>
Either one works fine. If you're running stock pistons and compression, I would run the BCP7Es. Because the plug does not protrude as far down into the combustion chamber (assuming the stock piston is domed).
Old Nov 9, 2004 | 09:29 PM
1SlowSi's Avatar
Default Re: NGK Users - BCP or BKR? (00ITR #543)
The only ones i can find online are the BKR's. Ill see once i get home. Im in Iraq now. HT is my morale booster.
Old Nov 9, 2004 | 09:46 PM
B O B's Avatar
id stay 7's
Old Nov 10, 2004 | 12:30 AM
1SlowSi's Avatar
Default Re: NGK Users - BCP or BKR? (B O B)
You really think ill have a problem with BKR's too deep in the chamber with my stock b16a2? i dunno....
Old Nov 10, 2004 | 07:32 AM
00ITR #543's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowSi &raquo;</TD></TR><TR><TD CLASS="quote">You really think ill have a problem with BKR's too deep in the chamber with my stock b16a2? i dunno....</TD></TR></TABLE>
Nope should be fine...
Old Nov 10, 2004 | 07:33 AM
M.A.R.C.'s Avatar
i've used BCPR7ES-11's and the R5671A-7's both were fine.
Old Nov 10, 2004 | 07:35 AM
raene's Avatar
No one locally sells the BKR7E-11s so I'm running ZFR7F-11 on my B16. They seem to work OK.
Old Nov 11, 2004 | 01:51 AM
1SlowSi's Avatar
Default Re: NGK Users - BCP or BKR? (raene)
I appreciate the help. I think i got what i needed to know.
Boostage
Aug 5, 2006 11:11 AM
Amused
Dec 13, 2005 08:14 AM
PrecisionH23a
Sep 29, 2004 08:22 AM
PUREVIL
Nov 20, 2003 04:53 PM
Blue-Civic-Hybrid
Jul 11, 2003 11:07 AM
