comp cams new turbo cams?
I know most people are saying to go with stock gsr cams. After looking at the specs on some of the new cams I was wondering if you guys think there would be any benifit to using the stage 2 or higher on B series running 15psi or higher.
I want to run around 17psi on my built gsr motor at 9.5:1 cmp. Do you think it would be worth the money?
Later Street_strip
Later Street_strip
Re: comp cams new turbo cams? (loserface)
bump finding out for a homie but info bout the stage 4's or what other cams would u recommend fully built 84.5mm gsr gt35r
Re: comp cams new turbo cams? (street_strip)
The Comp cams will definitely raise the rpm level that you will obtain full torque and horsepower along with raising the max power numbers also.
Re: comp cams new turbo cams? (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl »</TD></TR><TR><TD CLASS="quote">The Comp cams will definitely raise the rpm level that you will obtain full torque and horsepower along with raising the max power numbers also.</TD></TR></TABLE>
would you recommend them or some other cams?
on my case the D series COMP cam 59300 lowered the point where i start making good torque and expanded theh power curve larger...
now turbo i haull *** on midrange power
Re: comp cams new turbo cams? (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC »</TD></TR><TR><TD CLASS="quote">on my case the D series COMP cam 59300 lowered the point where i start making good torque and expanded theh power curve larger...
now turbo i haull *** on midrange power</TD></TR></TABLE>
any pics on stock cam vs. 59300 cam? I know with my turbo D the motor stopped making good power way earlier with the stock cam than the 59300.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl »</TD></TR><TR><TD CLASS="quote">if the car is on the street, type r's would be great to 600hp</TD></TR></TABLE>
yea its his daily driver now since he blew the motor to his beater
SIReg9
08-13-2003 03:18 PM
