what do i need from summit for catch can?
Old Nov 10, 2004 | 09:07 PM
PA MATT's Avatar
Default what do i need from summit for catch can?
I'm looking to make a catch can and I have like 20 bucks i think to use at summit, they gave it to me for doing business with them. What do they have that I can use as a can? I looked on their site and did a quick search and haven't stumbled across anything....any help?
Old Nov 11, 2004 | 08:21 AM
PA MATT's Avatar
Default Re: what do i need from summit for catch can? (PA MATT)
bump
Old Nov 11, 2004 | 10:04 AM
4_door_teg's Avatar
I don't know about summit but you can make you one 20 bucks no problem. I got all my supplies at canadian tire but I'd imagine a home depot or sometihng like htat will work.
things you need:
2 brass fittings with 3/8" nipples
some sort of sealing adhesive
some sort of canister. I used a cup with a lid.
some 3/8" hose
Some sort of steel wool or spounge
Once you have everything, drill a hole in your canister around the middle and another above it near the top. Put some adhesive on your fittings and screw them in. seal the lid and fittings with a generous amount of adhesive. Once its all dry you can install it. I put mine between the pcv valve and the im. It won't look the sexiest but who cares, it work. Oh yea, make sure to put hte steel wool in before you seal it haha.
Old Nov 11, 2004 | 10:11 AM
PA MATT's Avatar
Default Re: (4_door_teg)
thanks for your help man, I've pretty much figured out im gonna go from valve cover to pvc if i dont have a vented can and if i do have a vented can ill go pvc to im.....im not completely decided quite yet. and i'll pry use a loafa(all girls use em in the shower) Just kinda looking for a container, but thanks again
edit: just found this http://store.summitracing.com/...=ecat
Old Nov 11, 2004 | 10:46 AM
4_door_teg's Avatar
Hey there you go, 30 bucks can't go wrong
Old Nov 11, 2004 | 11:08 AM
PA MATT's Avatar
do you think a 6-an fitting would be sufficient or just get it and take that out, drill that hole out, drill another one and put some larger fittings in? I dont really think i'd be able to put anything in there like steel wool or anything. it'd be like 9 bucks since i have 20 bucks free from the certificate they gave me
ANTI_LAG
Welding / Fabrication
17
May 24, 2012 12:54 PM
Whatever
Sep 4, 2009 12:26 PM
03EM2guy
May 13, 2008 10:29 AM
accordfreak93
Mar 14, 2003 07:49 AM
baonest1
Mar 2, 2003 08:58 PM
