what kind of HP/TQ gains have u seen with a bigger TB?
just curious to see what people have gained by adding a bigger TB into the mix....thanks for any replies guys....
Re: what kind of HP/TQ gains have u seen with a bigger TB? (B20luda)
I saw no gains on a JRSC @ 6 psi on a B16A2. Stock vs 64mm RC Eng bored out throttle body. Curves were exactly the same. So, I sold the bored TB and started saving for Hondata.
Keep in mind that this with a low boost setup running an FMU. Gains would probably be there for a higher boost setup with good engine management.
Sonny
if u upgrade your intake manifold then it is a good idea to upgrade throttle body... if your just doing throttle body then its not going to do anything...
Re: what kind of HP/TQ gains have u seen with a bigger TB? (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd »</TD></TR><TR><TD CLASS="quote">if u upgrade your intake manifold then it is a good idea to upgrade throttle body... if your just doing throttle body then its not going to do anything...</TD></TR></TABLE>
you said it
you said it
