oil pump gear question.
Old Nov 9, 2004 | 10:10 AM
boostedeg22's Avatar
Default oil pump gear question.
is upgraded oil pump gear a must on turbo vehicle?i'm thinking about buying a itr oil pump well that be o.k. or should i buy a prodrive?tryed search did not find anything
Old Nov 9, 2004 | 10:35 AM
Default Re: oil pump gear question. (boostedeg22)
help needed
Old Nov 9, 2004 | 11:22 AM
boostedcivicsir's Avatar
Mr. Badwrench
i have been told the sintered metal stock oil pump gears dont hold up. i havent seen one fail yet, but if you are racing the car constantly, i think it would be a good upgrade. i have also heard that if you run an underdrive crank pulley, there is no harmonic dampening and that will cause it to fail. if anyone has more input, let me know as well. i am a little too far into mine to turn back now but would like to know.
Old Nov 9, 2004 | 01:26 PM
Default Re: oil pump gear question. (boostedcivicsir)
thanks for reply more info needed
Old Nov 9, 2004 | 03:28 PM
bump^
Old Nov 9, 2004 | 05:23 PM
earl's Avatar
Seems like the stock ones last as long as the good ones. If there is a problem, either one will break equally as quick.
TOM2RN
Sep 20, 2013 02:44 AM
djnikko
Aug 17, 2006 06:41 AM
Trooper
Oct 28, 2003 01:12 PM
Boostless97Lude
Sep 23, 2002 02:44 PM
PROFILES2000
Feb 25, 2002 01:17 PM
