Emissions Testing in MD
Old Nov 8, 2004 | 10:42 AM
jmal1919's Avatar
Default Emissions Testing in MD
Ok, here's the deal. I need to go through emissions testing. I'm running 440 injectors controlled by the SAFCII on the f23a1 OBDII motor, with a cat. I get 2 codes thrown which is expected running the hack (running too rich and fuel air metering). I thought that I could pass emissions testing by clearing the codes and going down to the station, but I was told to come back because there weren't any readiness codes yet. I was told to drive 300 miles or so and come back. I figured that I could baby it and not have any codes thrown and pass, but babying it isn't working, got a code for "running too rich" thrown.
I need some tips to pass testing, please help! Please post, or PM with ideas.
Thanks
Old Nov 8, 2004 | 10:48 AM
pip9's Avatar
Default Re: Emissions Testing in MD (jmal1919)
The codes are going to keep coming up unless u fix why they are coming up... ie dont run the hack. There are plenty of shady emission stations you could go to they would pass it though. I ran the hack for awhile but i was OBDI, im not sure about all the problems with running it with OBDII but maybe converting it would get rid of the codes.
You could move to St. Mary's County... they have no emissions
Old Nov 8, 2004 | 10:52 AM
Joseph Davis's Avatar
Default Re: Emissions Testing in MD (pip9)
Yup, the hack on OBD2 is going to be a very unhappy thing when it comes to a legit inspection.
You can always injector swap, set the AFC to 0, and drive 300 miles without boost.
Old Nov 8, 2004 | 10:58 AM
jmal1919's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pip9 &raquo;</TD></TR><TR><TD CLASS="quote">The codes are going to keep coming up unless u fix why they are coming up... ie dont run the hack. There are plenty of shady emission stations you could go to they would pass it though. I ran the hack for awhile but i was OBDI, im not sure about all the problems with running it with OBDII but maybe converting it would get rid of the codes.
You could move to St. Mary's County... they have no emissions </TD></TR></TABLE>
I know the codes are going to keep comming, the hack is temporary until the EMS comes. When I do switch to the EMS, I will still have this problems since I'm OBDII, the EMS will not respond to the OBDII port, thus I fail/ come back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">Yup, the hack on OBD2 is going to be a very unhappy thing when it comes to a legit inspection.
You can always injector swap, set the AFC to 0, and drive 300 miles without boost.</TD></TR></TABLE>
How easy would it be to swap the stock injectors back in? I have RC injectors currently now with the clips wired in.
Old Nov 8, 2004 | 11:28 AM
bluemax189's Avatar
i live in MD too, what county you in? well anyways, injector swap is not that hard, done it a couple times, go buy OBD1 injectors from a junkyard(because you said you had the rc's wired up) and first, relieve fuel pressure, un bolt fuel rail, pull off, fuel will come out all over the place, catch with rag, take out old injectors, put in new, put fuel rail back on, tight up banjo bolt on fuel filter to regain/retain fuel pressure, and your good to go.
Old Nov 8, 2004 | 12:55 PM
jmal1919's Avatar
Default Re: Emissions Testing in MD (bluemax189)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluemax189 &raquo;</TD></TR><TR><TD CLASS="quote">i live in MD too, what county you in? well anyways, injector swap is not that hard, done it a couple times, go buy OBD1 injectors from a junkyard(because you said you had the rc's wired up) and first, relieve fuel pressure, un bolt fuel rail, pull off, fuel will come out all over the place, catch with rag, take out old injectors, put in new, put fuel rail back on, tight up banjo bolt on fuel filter to regain/retain fuel pressure, and your good to go. </TD></TR></TABLE>
I still have my stock injectors, so will I need to modify any wiring for them? I'm going to PM you a few more things.
Old Nov 8, 2004 | 02:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmal1919 &raquo;</TD></TR><TR><TD CLASS="quote">How easy would it be to swap the stock injectors back in? I have RC injectors currently now with the clips wired in.</TD></TR></TABLE>
Low Z injectors, just use OBD0 units.
High Z injectors, just use OBD1's with the plastic center tang snipped out.
Old Nov 8, 2004 | 04:46 PM
jmal1919's Avatar
Default Re: Emissions Testing in MD (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">Low Z injectors, just use OBD0 units.
High Z injectors, just use OBD1's with the plastic center tang snipped out.</TD></TR></TABLE>
Still learning, but is it possible to use my stock injectors? OBDII
Old Nov 8, 2004 | 04:48 PM
94gsr4dr's Avatar
i just keep asking for extensions and they give them too me. Much easier then actually testing the car.
Old Nov 8, 2004 | 04:52 PM
jmal1919's Avatar
Default Re: Emissions Testing in MD (94gsr4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr4dr &raquo;</TD></TR><TR><TD CLASS="quote">i just keep asking for extensions and they give them too me. Much easier then actually testing the car.</TD></TR></TABLE>
I thought about that. But does that work,cause eventually ur tags need to be renewed and I believe they will not do it if it hasen't passed emissions?
Old Nov 8, 2004 | 04:57 PM
pip9's Avatar
how do they do emission now in md? I remember my friends telling me they would just lower their car so low that they wouldn't be able to put the car up on the lifts they use for testing so they would be waved. They didn't have cel's on so i donno if they still had to get the car hooked up to the scan tool.
Would converting to OBDI help u out? or would that just be illegal in itself since the emissions devices back then were not as strict.
Old Nov 8, 2004 | 05:02 PM
jmal1919's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pip9 &raquo;</TD></TR><TR><TD CLASS="quote">how do they do emission now in md? I remember my friends telling me they would just lower their car so low that they wouldn't be able to put the car up on the lifts they use for testing so they would be waved. They didn't have cel's on so i donno if they still had to get the car hooked up to the scan tool.
Would converting to OBDI help u out? or would that just be illegal in itself since the emissions devices back then were not as stict.</TD></TR></TABLE>
For OBDII cars, all they do is hook up the computer to the OBDII diag port and check for any codes.
For OBD0 & OBDI, they place the cars on the dyno with the tailpipe test.
Since my car is OBDII by nature, if I converted to OBDI I would still fail.
Old Nov 9, 2004 | 12:30 PM
pip9's Avatar
I would just do what he suggested then.
Old Nov 9, 2004 | 01:47 PM
dwnthehatch's Avatar
If you have coilovers, drop your car so it is barely drivable. Come to the Annapolis Emissions station and they will give you a waiver since you can't get on the dyno. You don't even have to pay the fee. It worked on my last three cars.
Old Nov 9, 2004 | 02:08 PM
jmal1919's Avatar
Default Re: Emissions Testing in MD (dwnthehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch &raquo;</TD></TR><TR><TD CLASS="quote">If you have coilovers, drop your car so it is barely drivable. Come to the Annapolis Emissions station and they will give you a waiver since you can't get on the dyno. You don't even have to pay the fee. It worked on my last three cars. </TD></TR></TABLE>
I don't have to get on the dyno since I'm OBDII. But do ya'll think that if I keep going back with OBDII readiness codes not there, the'yll just let me through?
Old Nov 9, 2004 | 02:57 PM
HybridHatchC1's Avatar
I am in MD, i just dump my car all the way to the ground(coilovers)... everytime they can't put it on the rollers so they just tell me to goto the office. Since i didnt get on the equipment they dont even charge me the $14. They sign me off and send me on my way.
Old Nov 9, 2004 | 03:23 PM
94gsr4dr's Avatar
Default Re: Emissions Testing in MD (HybridHatchC1)
you don't even have to do that, just apply for an extension online.
Old Nov 9, 2004 | 05:48 PM
jmal1919's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr4dr &raquo;</TD></TR><TR><TD CLASS="quote">you don't even have to do that, just apply for an extension online.</TD></TR></TABLE>
how long do they keep giving extensions?
Old Nov 9, 2004 | 06:48 PM
94gsr4dr's Avatar
6 months a time. I have done 2 in a row now.
Old Nov 9, 2004 | 07:01 PM
jmal1919's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr4dr &raquo;</TD></TR><TR><TD CLASS="quote">6 months a time. I have done 2 in a row now.</TD></TR></TABLE>
have u had to get new stickers in between that time?
Old Nov 10, 2004 | 06:08 AM
94gsr4dr's Avatar
i am trying to think if they came after i got my first notice, but before i asked for my first extension. I want to say i already had an extension before i got my new tags, but i may be wrong. Just write them an email and ask if you will still get sticekrs.
92blkJDMh22
Oct 16, 2006 12:11 PM
98IntegraLSNonVtec
May 16, 2006 04:46 PM
RedRocketCRX
Jun 22, 2004 05:51 AM
N hatch
Jun 7, 2004 09:24 PM
MeanGreenEG9
Jun 12, 2003 08:39 PM
