Whats safe to boost?
Old Nov 8, 2004 | 10:07 AM
91DroppedHatch's Avatar
Default Whats safe to boost?
I wanna build a B20 block for turbo that can withstand 15psi daily driven. The only question is what should I do to the block so it can take it? Anyone have a list or anything, any opinions would be nice thank you.
Old Nov 8, 2004 | 10:20 AM
RobbieG35's Avatar
12 Years Strong
Default Re: Whats safe to boost? (91DroppedHatch)
Sleeves, pistons, and rods - The stock sleeves may be ok, but I wouldnt risk it
Old Nov 8, 2004 | 10:28 AM
Lucky_Smurf's Avatar
Default Re: Whats safe to boost? (HybridHatch88)
What turbo? That makes a big difference. You can't just say 15psi because 15psi on 14b or 15psi on a pt67 is a big difference.
That being said I agree with previous poster, pistons, rods, sleeves.
Old Nov 8, 2004 | 11:13 AM
a garrett T3/T04E 60 trim
Old Nov 8, 2004 | 01:58 PM
Default Re: (91DroppedHatch)
You could probably get away with 15psi on stock sleeves with race gas but getting away with it and doing it safely are two different things. I say always sleeve, otherwise your dealing with a ticking bomb.
Old Nov 8, 2004 | 03:47 PM
D-tuned's Avatar
Default Re: (Lucky_Smurf)
I just tuned my stock LS and make 310WHP and 274WTQ @ 20psi with a t3/t4 57 trim with stage III wheel .50/.63(check my sig). I rebuilt the motor so it had 0 miles on it. You cant post a question asking who much psi can you run because this depends on the motor,the turbo,and most important tuning how much power your going to make at a certain psi. The question you need to be asking is what do you need to do to your motor to get a certain HP goal. I sure once you know what your HP goal is people on here will be more that happy to point you in the right direction.
Old Nov 9, 2004 | 04:27 PM
Default Re: (2000civicsi)
Well my main hp goal is to be around 300-400, so basically what all do I need to do to a B20 motor to reach this hp amount?
Old Nov 10, 2004 | 12:42 AM
Yeah a b20 will do it. Just find yourself a good builder.
Old Nov 10, 2004 | 08:03 AM
I wanna build it, I just dont wanna go over board with things I dont need to reach 300-400hp. Im just asking if anyone know s what needs to be done, for instance I know I gatta sleeve it to get higher boost, but what else to reach 300-400hp.
Old Nov 10, 2004 | 09:00 AM
shadow103rd's Avatar
The Sleeves on the B20 are its weak point!!!!
But if you plan to rebuild with upgraded sleeves, this doesnt mean anything!
Jon
Marlon88
Jul 9, 2005 06:05 PM
Mr.DC2TurBo
Dec 16, 2003 12:49 AM
Fuzion
Nov 25, 2003 07:03 PM
TurboEKd16z6
Aug 7, 2003 12:28 PM
1.8T_EG
Feb 5, 2003 12:52 PM
