Nitrous and Propane
Old Nov 11, 2004 | 03:41 PM
CarAudiophile's Avatar
Default Nitrous and Propane
Anyone do this?..
What I am talking about is running Propane as the fuel and running the regular Nitrous through a wet kit..
Does this work and has anyone had any experience with it?...
Old Nov 11, 2004 | 03:49 PM
MooreBoost's Avatar
Default Re: Nitrous and Propane (CarAudiophile)
Ive never done it but I hear great things about it. Unfortuneatly there arent many resources as far as that setup, but there are a few people that do it on here. The setup is alittle more complicated that you would think, essentially you need what a propane kit provides along with the nitrous kit, so it probably isn't cheap.
Old Nov 11, 2004 | 03:50 PM
Archidictus's Avatar
Unceasing Measure
If you can find a way to meter the Propane as it enters the intake manifold you'd be set. Unfortunately, gaseous propane won't work through regular fuel injectors with the same results as gasoline.
Running propane in combination with gasoline has long been a method of allowing more boost or timing while avoiding detonation. In that instance you can just run a single fogger nozzle in the intake tube or you could multi-port it like nitrous if you wanted to get serious. Turbo diesel trucks do it all the time.
Old Nov 11, 2004 | 04:27 PM
I have the Wet kit right now.. So what your telling me its not as easy as getting a propane tank.. Tapping it and running it into the Fuel Silonoid on the fuel side of the Nozzle?..
Old Nov 11, 2004 | 04:29 PM
MooreBoost's Avatar
Default Re: (CarAudiophile)
No, you need to run a propane regulator, and one more thing I think, I can't remember what it is though.
Old Nov 11, 2004 | 05:59 PM
Zackyt's Avatar
Default Re: (tegunderpressure)
i think ive seen propane kits for like $300, you could probably get every thing you need from that, as long as you figure out what size jet for the propane, to run with whatever nitrous shot your spraying (maintain proper af etc)
Old Nov 11, 2004 | 07:04 PM
stinker504's Avatar
http://www.importpoweronline.c....html Here is a link to a company that sells propane kits.
http://www.importpoweronline.c...=1117 Also sold here for only 375.00.
Old Nov 12, 2004 | 08:08 AM
looks like this could be done then.. I would probablly start off with a small shot on the dyno and work it out off that baseline.. But has anyone on here done this.. I may do it to the B16 for right now to test it out.. But I really don't want to blow the new motor trying this out..
Old Nov 12, 2004 | 10:38 AM
turbogeekDA6's Avatar
in order to do this you have to have liquid propane. all the kits you see here are dry flow. they are just anti-detonation kits. liquid propane is not as user-friendly as gaseous propane. you have to have another tank, nitrogen feed, that displaces the propane. even then the flow rate can change; it doesnt work as well as gas. i looked into the same thing a while back and this is what an authority told me. despite all the people that say it wont work, im still gonna try the dry flow propane on top of the wet nx kit. surely the thing will run a little rich, but one can always lean out their setup a hair. imho that its best use is on a turbo car with a dry flow kit. if you find any useful information on making liquid propane work as a fuel for nitrous, post it here, please. goodluck!
Sr420Det
Feb 29, 2008 08:09 PM
wrXtian
Apr 27, 2004 11:27 AM
BLK JDM
Feb 26, 2003 08:17 AM
EGkTiOn_CiViC
Dec 22, 2002 03:51 PM
2.2dc2
Jun 25, 2002 11:56 AM
