NEW IGNITION SETUP
Old Nov 8, 2004 | 05:24 PM
Tex Blackwell's Avatar
Default NEW IGNITION SETUP
I just got this box, and i was just wanting to make sure if anyone else had heard about this ignition box, it uses a different HVC coil than the standard one that is available everywhere.
This setup should work fine on a boosted dohc hondata engine
I want to use this ignition system along with the rev limiter and 2 step
HVC High Current Ignition
Professional Race Ignition PN 6600
i'll use the msd cap n wires with
the HVC coil pn8250
http://img106.exs.cx/img106/1012/Dscn5078.jpg
what do you guys think, not too much ignition?
Modified by mp3albums2k2 at 2:38 AM 11/9/2004
Modified by mp3albums2k2 at 3:11 AM 11/9/2004
Modified by mp3albums2k2 at 3:50 AM 11/9/2004
Modified by mp3albums2k2 at 11:41 AM 11/9/2004
Old Nov 9, 2004 | 07:39 AM
Default Re: NEW IGNITION SETUP (mp3albums2k2)
anyone?, looks like it would be a good combo
Old Nov 9, 2004 | 08:12 AM
Joseph Davis's Avatar
What standard one that is available everywhere? MSD 6AL? Worthless, and IU'd speculate this HVC is worthless, too.
As for the coil - do you know the specs on the primary vs secondary windings, or at least kV in layman's terms? How does that compare to the "standard" one?
BTW, avoid the MSD wires. Nothing works better than good old OEM.
Old Nov 9, 2004 | 09:17 AM
Default Re: NEW IGNITION SETUP (J. Davis)
the standad HVC coil,
http://www.msdignition.com/coil_blaster_14.htm
Old Nov 9, 2004 | 09:19 AM
its just that msd says that you cant use the different hvc coil like the one posted rite above, you would have to use the hvc coil posted above the ignition box
1slowcrx
Oct 28, 2004 04:33 AM
vtekthis
May 1, 2004 03:28 PM
MugenGTR
Mar 31, 2003 01:38 PM
