thick hg's
Old Nov 12, 2004 | 01:56 PM
TegRaceR98's Avatar
Default thick hg's
how much do head gaskets lower compression, and what is the best to buy
wantboost's Avatar
Who is Mr Robot?
Default Re: thick hg's (TegRaceR98)
depends on what kind of gasket you buy. cometic makes good ones, but they are $$
Old Nov 12, 2004 | 01:59 PM
TegRaceR98's Avatar
i dont care how much what lowers it the most
Old Nov 12, 2004 | 02:00 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (TegRaceR98)
depends on the thickness, google is your friend.
Old Nov 12, 2004 | 03:06 PM
BoostR41's Avatar
Default Re: (wantboost)
I have a inline pro head gasket coming out of my motor now....I will sell it for 100 bucks....all you will need is 2 factory honda gaskets to sandwich the plate in....it drops compression one full point
Old Nov 12, 2004 | 04:59 PM
Tchleung's Avatar
cometic makes a .120 gasket now which drops it almsot a full 2 points...
Old Nov 12, 2004 | 06:14 PM
Ek00fbp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TegRaceR98 &raquo;</TD></TR><TR><TD CLASS="quote">how much do head gaskets lower compression, and what is the best to buy</TD></TR></TABLE>
the thicker it is the lower it will go, so there is ur answer. now how low it goes from the .XXX I don't know. but if u resurface ur head the same amt. it will even out.
Old Nov 12, 2004 | 08:52 PM
PHiZ's Avatar
Default Re: thick hg's (Ek00fbp)
Is this the RIGHT way to lower compression on a motor that is going turbo. Or is it considered a hack?
-PHiZ
Old Nov 12, 2004 | 10:59 PM
TegRaceR98's Avatar
Default Re: (Tchleung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">cometic makes a .120 gasket now which drops it almsot a full 2 points...</TD></TR></TABLE>
like 2.0 or .2?
Old Nov 12, 2004 | 11:23 PM
Tchleung's Avatar
2.0
Old Nov 12, 2004 | 11:34 PM
Maveric's Avatar
imo....thicker headgasket isnt the right way to lower comp.
Old Nov 13, 2004 | 12:20 AM
Adi Radoncic's Avatar
On Fire!
.120 = 3mm it takes the compression of a gsr motor down to about 9.2:1.
And yes this really isn't the right way to lower your compression but its cheaper than pistons, machining and in some cases downtime.
The difference between a stock motor and droping the compression with a headgasket is about 50-60whp extra that you are going to gain, this is with a turbo kit and some good tuning.
If you look around here your gona see a lot of stock motor setups dynoing anywhere from 290whp to 310whp (B-series), now with a headgasket your looking at about a 350-370whp dyno chart.
With a headgasket like this your gona have some leaks here and there like coolant seepage as well as oil if not installed correctly.
Old Nov 13, 2004 | 03:35 AM
integlspwr2k's Avatar
Default Re: (newgsr)
nothing wrong with thicker headgasket. its been proven and it works.
Old Nov 13, 2004 | 04:25 AM
boostjunkie757's Avatar
Default Re: (integlspwr2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsr &raquo;</TD></TR><TR><TD CLASS="quote">.120 = 3mm it takes the compression of a gsr motor down to about 9.2:1.
bingo.
its a cheap way to make either a lot more power that will break down in the same amount of time as without it, or a little more power and last a little longer.
Old Nov 13, 2004 | 07:04 AM
TegRaceR98's Avatar
so, best one to get?
Old Nov 13, 2004 | 07:19 AM
ive heard good things about the inline pro headgaskets...
Old Nov 13, 2004 | 08:14 AM
Tchleung's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsr &raquo;</TD></TR><TR><TD CLASS="quote">.120 = 3mm it takes the compression of a gsr motor down to about 9.2:1.</TD></TR></TABLE>
where did you get that info?
On c-speed racing and other C/R calculators it drops a GSR to 8.26:1 and a b16 to 8.21:1
Old Nov 13, 2004 | 08:31 AM
TegRaceR98's Avatar
where can i get that head gasket
Old Nov 13, 2004 | 09:06 AM
Tchleung's Avatar
I believe some of the sponsors here carry them.. check in the FI sponsor section or jsut do a search for Cometic .120" I remember a sponsor posting about it.
Old Nov 13, 2004 | 10:17 AM
BoostR41's Avatar
Default Re: (boostjunkie757)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostjunkie757 &raquo;</TD></TR><TR><TD CLASS="quote">ive heard good things about the inline pro headgaskets...</TD></TR></TABLE>
they are the best like I said earlier it has been in my car for 2 years at over 1bar of boost and not one issue. it is 3mm and drops compresson 1 point.
Old Nov 13, 2004 | 10:43 AM
yah, mine lowers compression by 1.1. stock itr internals are supposed to be strong, so im testing that theory. at 9.5:1, it could handle more than 11 psi, but i dont want to push it THAT much.
Old Nov 13, 2004 | 10:53 AM
BoostR41's Avatar
your HP is gettin up there for the stock ring lands but I ran 1.1bar on 114/93 mix so the gasket holds that with about 300whp
Old Nov 13, 2004 | 11:07 AM
SOHC_MShue's Avatar
With a headgasket like this your gona have some leaks here and there like coolant seepage as well as oil if not installed correctly.</TD></TR></TABLE>
i don't see how lowering your compression that much with a thicker headgasket is gonna gain you hp. Your just gonna have to run more boost to make up for the loss in compression.
Old Nov 13, 2004 | 11:17 AM
Civic_95_Si's Avatar
The Greddy gasket for the D16 lowers it .6
So for a D16Z6 it would be 8.6:1.
Old Nov 13, 2004 | 11:21 AM
Default Re: (BoostR41)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostR41 &raquo;</TD></TR><TR><TD CLASS="quote">your HP is gettin up there for the stock ring lands but I ran 1.1bar on 114/93 mix so the gasket holds that with about 300whp</TD></TR></TABLE>
my car RARELY sees full boost....even on low boost.
