cams with nitrous ?
Old Nov 9, 2004 | 02:53 PM
BlackRocket's Avatar
Default cams with nitrous ?
can i run nitrous on big cams or do i have to getting a smaller stage cams to run a good shot of nitrous like a 75 shot. for example can i run the rocket motorsports M22 cams and valvetrain with the 75 shot or wouldnt the big cams work well with nitrous
Old Nov 9, 2004 | 05:51 PM
night time bump
Old Nov 9, 2004 | 06:36 PM
mstyper's Avatar
Default Re: cams with nitrous ? (SprayinR21)
what type of car??
you should not have to change the cams....
Old Nov 10, 2004 | 07:24 AM
It is a B18c JDM Type R motor in a 96 civic hatchback. my bad
Old Nov 10, 2004 | 12:04 PM
RyanEJ8's Avatar
Cams with alot of overlap might blow a little nitrous out of the exhaust valves, but there is no need to change the cams because of this.
Old Nov 10, 2004 | 02:50 PM
so your saying with more aggressive cams i might blow nitrous out of the exaust valves and have more of a chance to blow the motor?
Old Nov 12, 2004 | 03:29 PM
JSpin's Avatar
Default Re: (SprayinR21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SprayinR21 &raquo;</TD></TR><TR><TD CLASS="quote">so your saying with more aggressive cams i might blow nitrous out of the exaust valves and have more of a chance to blow the motor?</TD></TR></TABLE>
it's more of an issue of loosing power, not so much as blowing your motor.
i'm using Blox 1's on a direct port setup.
Old Nov 14, 2004 | 08:18 PM
Icey112's Avatar
im using skunk2 stage 1 and the nx wet kit .
Old Nov 14, 2004 | 10:50 PM
raceACCORDingly's Avatar
when you go with high duration/high lift cams, the valves stay open longer, not burning all the nitrous , making it to puddle up and go to waste it in the valve chambers. no engine blowing up but your just not gonna get the full potential power from the nitrous.
nitrous will respond better if the increased exhaust duration is gained by opening the exhaust valve earlier in the cycle. advancing the exhaust cam with a cam gear will help get the full potential shot
Old Nov 15, 2004 | 09:26 AM
Default Re: (raceACCORDingly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceACCORDingly &raquo;</TD></TR><TR><TD CLASS="quote">when you go with high duration/high lift cams, the valves stay open longer, not burning all the nitrous , making it to puddle up and go to waste it in the valve chambers. no engine blowing up but your just not gonna get the full potential power from the nitrous.
nitrous will respond better if the increased exhaust duration is gained by opening the exhaust valve earlier in the cycle. advancing the exhaust cam with a cam gear will help get the full potential shot</TD></TR></TABLE>
thanx man good response thats what ive been lookin for the whole time
Old Dec 21, 2004 | 05:12 PM
whatVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceACCORDingly &raquo;</TD></TR><TR><TD CLASS="quote">nitrous will respond better if the increased exhaust duration is gained by opening the exhaust valve earlier in the cycle. advancing the exhaust cam with a cam gear will help get the full potential shot</TD></TR></TABLE>
I'm running nitrous on a B18b with some Crower 404's......both gears are at 0.
So it would be beneficial to advance the exhaust cam? How many degrees?
Old Dec 21, 2004 | 06:10 PM
Aggressive Racing's Avatar
I agree had a B18c5,12:5:1comp,and toda c's,made 219 all motor,341 with shot,368 when moved the exhaust cam.
It felt like someone hit me with a truck from behind when i hit that button
DAM THAT FELT GOOD
Old Dec 21, 2004 | 06:37 PM
whatVTEC's Avatar
Default Re: (aggressivemotorsports)
how much did you move the cam?
did you do intake and exhaust, or just exhaust?
gents97civ
May 1, 2005 02:45 PM
BolivianDc2
Aug 24, 2003 08:10 AM
F120man
Oct 31, 2002 05:25 PM
