Hondata S200B CEL_7
Old Nov 10, 2004 | 09:30 PM
Pssst!'s Avatar
Default Hondata S200B CEL_7
Prior to my Hondata install I had a stock gsr running on a p72 with no CEL's for years, but when I installed my Hondata I got a CEL_7 TPS code.
I reinstalled the stock ecu and no codes, but again a code 7 reinstalling Hondata. Not sure why this code is coming on car seems to be running fine with base map supplyed for my setup(I Guess).
Not sure if my VAFC might have anything to do with it but it reads TPS voltage.
Can this be caused by a faulty connection between ecu and ecu plugs or can the fact that my Hondata ecu was a p06 auto ecu have anything to do with it?
One thing that I did notice, when the p72 was back in the TPS reading on the vafc was 4% off throttle(off the gas pedal).
Any help or experience you can give me PLEASE post.
Old Nov 11, 2004 | 06:17 AM
Pssst!'s Avatar
Default Re: Hondata S200B CEL_7 (Pssst!)
Before work bump
Old Nov 11, 2004 | 02:34 PM
Spunkster's Avatar
remove the VAFC and check the tps voltage at idle...it should be .49 volts.
Old Nov 11, 2004 | 04:28 PM
Pssst!'s Avatar
Default Re: Hondata S200B CEL_7 (Spunkster)
Well I thought it was .45 volts checked it today and it was at .50 volts, I checked voltage by removing ecu cover and connecting meter on bridge pin (metal strip connecting ecu pin outs to motherboard) and ECU mounting bracket for ground. Turned out to be open at ecu pins, so I just bend the pin for the TPS signal and CEL gone.
Old Nov 11, 2004 | 04:30 PM
FastANDFURIOUS
Guest
Posts: n/a
look it up online
sackdz
Engine Management and Tuning
Sep 29, 2009 06:14 AM
d!zZy
Jul 13, 2005 05:11 PM
rondigs
Feb 24, 2005 01:12 PM
redboost10
Oct 29, 2003 07:53 PM
