Building a fuel system
Old Nov 9, 2004 | 07:32 PM
GT61 this 1.8t's Avatar
Default Building a fuel system
basicly what i have is a 12 gallon cell with -10 fittings in the sump...
basicly im trying to find the best place to buy all my parts...
and also to check with you guys to see what im missing....
so starting at the cell working to the rail.
socketless -10 hose end from -10 fitting on cell to small 4ft section of socketless line (-10) to another -10 socketless hose end which then connects to the aeromotive 10micron filter via -10an to -10an male to male fitting, filter to pump via -10an to -10 oring union, then another -10o-ring/union to -10 an on the front side of the pump, -10 hose end to 10ft section of socketless -10 aeroquip hose, another -10 hose end to fuel rail with -10 fittings.
now for the return side of things.
mount FPR directly to rail or run lines to it?
basicly -10 o-ring to -6an to -6 socketless hose end, -6 line to -6an/-6 union into FPR, -6union/-6an fitting in FPR out to -6 hose end to to 13ft of -6 aeroquip socketless hose to -6 hose end back into the cell....
so basically here is the list i have compiled from summit...
however summit doesnt have the -10 to -10 oring fittings instock until the 6th of december.
and i need to order this **** tomorrow...
just want to make sure everything is in check.
so please post thoughts
[b]
Part # Item Price Qty Line Total Delete
QTY-1 AEI-11101 Aeromotive A1000 Fuel Pumps $289.88 $289.88
QTY-1 AEI-12301 Straight-through design, flows 1,200 psi, 10 micron element, fuel filter $79.95 $79.95
QTY-1 AEI-13109 Red/Clear anodized finish, adjustable 30 to 70 psi pressure, -6AN inlet and outlet ports, fuel injection, pressure regulator $131.95 $131.95
Qty- 4 socketless hose ends -6an
Qty- 15ft socketless -6 hose
Qty- 2 fittings -6 o-ring to -6an for FPR
Qty- 1 -6 Plug for FPR
Qty- 15ft aeroquip socketless -10 hose
Qty- 3 aeroquip -10 hose ends (straight)
Qty- 1 aeroquip -10 45 degree hose end (from cell to filter)
Qty- 2 aeroquip -10an to -10an coupler to join filter to pump nad line to filter
Qty- 2 aeroquip -10 oring union to -10an (for each end of the fuel pump)
Select All
$684 shihpped.
Modified by GT61 this 1.8t at 4:43 AM 11/10/2004
Old Nov 9, 2004 | 10:44 PM
Default Re: Building a fuel system (GT61 this 1.8t)
man no fuel guys in here?
bump
B R Fittings
Nov 18, 2011 10:24 PM
D16SohcVtec
Jun 27, 2008 07:01 AM
Cprace1
Oct 16, 2007 01:39 PM
98lude
Apr 11, 2002 06:20 PM
