p28 ecu on dx motor and uberdata question.....
Old Nov 10, 2004 | 06:58 PM
JDM96SpecCTR's Avatar
Default p28 ecu on dx motor and uberdata question.....
a stock p28 on a dx....will it run ok? i just put one on my 96 dx and the idle was horrible and had a code 21 for vtec solenoid....took that off right away
and with uberdata, can u make a non vtec ecu run vtec by selecting the options and wiring it up? and i guess u would be able to only wire the solenoid if u disable the other vtec requirements correctt??
Old Nov 10, 2004 | 09:31 PM
eastbay92cx's Avatar
Default Re: p28 ecu on dx motor and uberdata question..... (JDM96SpecCTR)
I suppose you could chip the p28 with a dx (p06?) program and disable vtec.
For the second question, yes you can convert a non-vtec ecu to work with vtec. Look at the pgmfi or uberdata forums.
Good luck.
skunk2unerz
21
Mar 12, 2016 03:16 PM
moz92
Oct 1, 2009 11:55 PM
1SickEG
Mar 12, 2007 04:13 AM
JD_B18CDX
Oct 21, 2002 08:22 AM
skunk2unerz
Aug 2, 2002 09:43 AM
