Here is my Dyno, Comments please
Old Nov 10, 2004 | 08:47 AM
mraudio13's Avatar
Default Here is my Dyno, Comments please
Here is my setup.
2001 Integra GSR
Stock internals
SFP mani and downpipe
3" exhaust
Turbonetics T3 Super 60 turbo
Front mount Inercooler
HKS standard wastegate with 6lb spring
HKS Blowoff Valve
TurboXS MBC
Hondata s200b
p28 W\ obd II-I Harness
Boost is set at 9psi and falls to 7psi
Old Nov 10, 2004 | 08:50 AM
RobbieG35's Avatar
12 Years Strong
Default Re: Here is my Dyno, Comments please (mraudio13)
Picture isn't working
Old Nov 10, 2004 | 08:55 AM
95GSRTT
Guest
Posts: n/a
Default Re: Here is my Dyno, Comments please (HybridHatch88)
Looks good except for your boost leak. Get that fixed and you wil have alot more power. With you having a vtec head, your torque should not fall off like that.
Old Nov 10, 2004 | 08:59 AM
mraudio13's Avatar
Default Re: Here is my Dyno, Comments please (95GSRTT)
How do i remedy the boost leak?
Matt
Old Nov 10, 2004 | 09:01 AM
95GSRTT
Guest
Posts: n/a
umm find out where it is coming from first lol. It could be a charge pipe, could be exhaust manifold, could be the wastegate, bov, many many things. if its falling off there is a problem somewhere. Only way to find out is testing it. Run some soapy water over your couplings to see if any bubbles come up, that will let you know if any air is getting through there.
Old Nov 10, 2004 | 09:05 AM
mraudio13's Avatar
ahh, Sorry for stupid Question. The guy that tuned it said i might have an exhaust leak. I purchased a Vacuum block that i am going to install this weekend. Thanks
Matt
Old Nov 10, 2004 | 10:03 AM
integ22's Avatar
nice numbers. Good to see a GSR with a t3. When does your setup hit full boost exactly?
Any engine shots?
Old Nov 10, 2004 | 10:09 AM
mraudio13's Avatar
Default Re: Here is my Dyno, Comments please (integ22)
full boost at about 4, 1st gear is insane I get NO traction. 2nd and 3rd pulls real hard. I just purchased an omnipower suspension. and traction bars. I am hitting the track this weekend will post some numbers then.
Matt
Old Nov 10, 2004 | 10:11 AM
Blown90hatcH's Avatar
What is your Vtec set at? Time for some suspension/traction upgrades/EBC to aid in traction.
Old Nov 10, 2004 | 10:13 AM
mraudio13's Avatar
Default Re: Here is my Dyno, Comments please (Blown90hatcH)
vtec is at 4700 i think?? I can't really tell
96 GSR-T
Dec 14, 2008 01:46 PM
hondamonkey
Aug 15, 2007 05:47 AM
eshlil
Mar 17, 2007 11:44 AM
calvinPGMFI
Mar 5, 2006 11:56 PM
18psi sohc
Jan 17, 2005 11:38 AM
