New JRSC setup
Old Nov 10, 2004 | 04:33 PM
moyosi's Avatar
Default New JRSC setup
well guys i just got some new toys for my beast.
I plan on doing the install my self but im still deciding, because here in mexico mechanics not know much about supercharged hondas.
Honda Civic si 2000 (B16A2)
(new stuff)
Jackson Racing Supercharger
JR Boost upgrade stage I
JR Vtec Controller
JR Map Sensor Controller
Hondata Intake Gasket
DC Sports 4-1 ceramic header
Memoryfab Carbon Fiber Intake System
Spec Clutch Stage III
Enjo Engine Mounts
B&M Oil Cooler
Transmision Bushings
Ignition Wires
Autometer ultralite gauges
-Air/Fuel
-Boost
-EGT
-Oil Pressure
-Gas Pressure
Short shifter
Radiato Cap
Lots of MOTUL Engine Oil
Lots of MOTUL Tranny Oil
(Old stuff)
REV Model VI 17x7
Yokohama Parada Spec II 205/40/17
TEIN STech Springs
Front/Rear Strut bar
Front/Rear Tie bar
Custom Catback system 2"
CTR Headlights
Please write your comments..
I'll post pics this weekend...
see ya.....
Old Nov 10, 2004 | 04:47 PM
MooreBoost's Avatar
Default Re: New JRSC setup (moyosi)
Sounds like a pretty good setup.
A few things though, I would run a different header, I believe it is the Kamikaze header that most people love, PM newgsrdriver and ask him. Also, make sure the kit/upgrade includes colder plugs. I was also about to suggest Hondata over the "bandaids" but I doubt theres anyone there to tune it. Infact, I would probably ditch the map and vtec controllers in favor of a missing link and fmu. Its simple, more reliable, and cheaper. The FMU will also be easy to tune yourself. Also, make sure the intake will work with the blower, I know on GSR's you have to run ITR intakes. I also hate Autometer gauges, I would consider GReddy gauges, and just get boost and oil pressure. The A/F gauges suck, and EGT isn't really necessary. For the fuel psi, just get a B&M that goes on your fuel filter. Also, during your install, watch the tension on the pulley carefully. If you overtighten it, it might induce chattering.
Good luck.
Old Nov 10, 2004 | 07:04 PM
moyosi's Avatar
tegunderpressure
Re: New JRSC setup (moyosi) 5:47 PM 11/10/2004
Good luck.
thanks man....... yes the JR boost upgrade stage 1 comes with, thermostat, colder plugas, crank puley, boost timming controller.
an about the headers i wanted to buy a kamikaze header but i was unable to find it, but i will try to find one for better results.
and about the mising link, FMU(i think JRSC comes with one) do i need hard tunning on thoes.....
thanks for the comments.
Old Nov 10, 2004 | 07:21 PM
Tad's Avatar
Tad
Hi,
glad to see another JRSC guy out there with so many turbo goons floating about!
The setup sounds great, you've really put alot into it,
I think maybe you went a bit overboard on some things.
But better more than less I suppose.
Anyhoo, don't mess around with a lower temp thermostat,
they cause more problems than they solve.
I'd recommend ditching most of JR's fuel tuning stuff, and getting bigger injectors
then dynotuning with uberdata or hondata or something along those lines.
oh and stick with oem honda wires, none of that aftermarket bullshit.
Old Nov 11, 2004 | 04:10 AM
MooreBoost's Avatar
Default Re: New JRSC setup (Tad)
The FMU is easy to tune, once screw, in or out. But you will just have to tune off how your plugs look. The missing link just bolts up and keeps your CEL off, no need for tuning. Also, the OEM spark plugs wires are more than adequate.
Old Nov 11, 2004 | 09:33 AM
moyosi's Avatar
Default Re: New JRSC setup (tegunderpressure)
yeah i will love to have it tune with hondata and all that but here in mexico is impossible to have it tune and there is such a thing as hondata tuners hehehehe
so i will have to stay with stock inyectors, and no hondata.
Old Nov 11, 2004 | 11:31 AM
Tad's Avatar
Tad
you can tune it yourself,
get a wideband o2 and a good gauge, do some street tuning.
yeah you'd have to learn how to tune it though.
so an fmu would be much easier.
by the way. The JR map controller does the same thing the missing link does, plus much much more. It taps into your ecu and lets your honda map sensor see boost,
also it helps the ecu put out better/more fuel.
Old Nov 13, 2004 | 04:59 PM
moyosi's Avatar
well lets see how it goes with my set up and if i don't like it ill try to tune myself...
thanks
TeH PLAYA
Jan 26, 2005 11:05 AM
2K Teggy
Dec 12, 2004 08:38 AM
moyosi
Nov 21, 2004 02:28 PM
2K Teggy
Jul 5, 2004 09:49 PM
ck279
Sep 4, 2001 04:33 PM
