10.8 compression LS... safe to turbo?
Old Nov 10, 2004 | 07:09 PM
Simple's Avatar
Default 10.8 compression LS... safe to turbo?
i built an LS motor with B16 pistons... according to the compression calculator on c-speedracing.com... my compression should be 10.8.
is this a safe CR to boost, at oh.... 10lbs?
Old Nov 10, 2004 | 07:33 PM
Soon_2b_evil's Avatar
Default Re: 10.8 compression LS... safe to turbo? (Simple)
yeha you'll be ok. Just make sure you get it tuned with someone who know what they are doing. Dont expect to boost 20psi on pump gas tho. Maybe 14psi at the highest on pump gas.
Old Nov 10, 2004 | 07:45 PM
TheShodan's Avatar
Moderator
^^^ Agreed...
Also, make sure that you pick the right turbo for that particular compression. LS's have different characteristics than the VTEC cuzins... But yes, it can be done.
jvk
Feb 20, 2011 02:28 PM
Rooftop voter
Nov 2, 2008 10:01 AM
LSEGHATCH
Oct 6, 2004 07:44 PM
Flexin5
Aug 31, 2004 02:58 AM
yisoulja
Dec 16, 2002 06:54 AM
