oil fitting for T3... need a source
Old Nov 11, 2004 | 09:47 AM
95hatch-NK's Avatar
Default oil fitting for T3... need a source
So on this T3 i got off a saab, the oil inleg a flat surface with two holes for bolts and a middle hole for oil... the middle hole for oil is threaded but only al little...
I think there should be a external threaded peice that i can thread the oil line into... this piece should have a center hole for the oil line that is threaded and two holes on either side of the oil line hole for the bolts - to bolt onto the turbo.
does anyone know what i'm talking about and where i could order one of these online nice and quick?
thanks...!
Old Nov 11, 2004 | 10:34 AM
RyanEJ8's Avatar
Default Re: oil fitting for T3... need a source (86hatchfire)
Check with Flamenco-T on this board. Or you can check out their website http://www.fast-turbo.com
Old Nov 11, 2004 | 10:39 AM
95hatch-NK's Avatar
Default Re: oil fitting for T3... need a source (RyanCivic2000)
I checked out the site, it had exactly what i'm looking for but for the oil out side, i'm looking for the oil in side... or does it matter?
thanks
Old Nov 11, 2004 | 10:42 AM
RyanEJ8's Avatar
Not really sure what you mean. Show me a pic?
Old Nov 11, 2004 | 11:24 AM
95hatch-NK's Avatar
that is the oil drain pic, i'm looking for something along those lines for oil imput... the turbo itself has a flat surface ready to accept somethign that would look just like that...
Old Nov 11, 2004 | 11:49 AM
Davep's Avatar
Ebay has a few
Old Nov 11, 2004 | 11:59 AM
RyanEJ8's Avatar
I don't think you need a flange for the inlet. The fitting should screw into the middle hole.
Old Nov 11, 2004 | 01:04 PM
Smooth-GSR's Avatar
The pics shown in the for oulet, running to your oil pan. So you still need that piece. The inlet side, I just used an elbow fitting, it should thread right into the hole, no flange needed. You should be able to find some pics on here.
Old Nov 11, 2004 | 01:15 PM
95hatch-NK's Avatar
Default Re: oil fitting for T3... need a source (Smooth-GSR)
thanks everyone!
Old Nov 11, 2004 | 03:15 PM
Bailhatch's Avatar
it's either threaded or not. In either case get an 1/8" NPT tap and either clean out the threads or cut new ones. An unthreaded feed hole in a saab T3 CHRA is 11/32" which is the proper size for a the NPT tap. The flange adapter is a waste of $15 and adds one more spot for a leak to occur.
Granty Boy
Jun 4, 2010 07:52 AM
Chee_dog
Aug 30, 2007 11:10 AM
boostin b16
Mar 15, 2003 05:44 PM
coseal
Jan 28, 2003 06:34 AM
