quick injector clip question
Old Nov 8, 2004 | 09:28 PM
whp
Guest
Posts: n/a
Default quick injector clip question
will the oem obd1 soch injector clips work with my precision 1000cc injectors? or will the RC ones work
i have an obd2 motor so i have saturated injectors right? are the precision 1000cc's peak and hold? will i need a resister box if they are peak and hold?
Old Nov 8, 2004 | 09:53 PM
whp
Guest
Posts: n/a
Default Re: quick injector clip question (h22eh2)
somebody?
Old Nov 9, 2004 | 02:22 AM
T-RO's Avatar
Are these the ones you have?
http://www.extremepsi.com/stor...age=1
Says they are peak and hold.
If you need injector clips I've always got some for sale (check sig).
Hope that helps
Old Nov 9, 2004 | 05:04 AM
whp
Guest
Posts: n/a
Default Re: (T-RO)
ok so if my injectors are satuated stock, i need a resister box right, since they are peak and hold?
Old Nov 9, 2004 | 06:05 AM
whp
Guest
Posts: n/a
Default Re: (h22eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22eh2 &raquo;</TD></TR><TR><TD CLASS="quote">
Old Nov 9, 2004 | 06:08 AM
Adi Radoncic's Avatar
On Fire!
both will work.
Old Nov 9, 2004 | 06:25 AM
SSBPGSR's Avatar
Default Re: (newgsr)
if your injectors are saturated you do not need a resistor box. and my obd1 clips DID fit my RC550's. you only need resistor box if the injectors are peak and hold. hope this helped
Adam
Old Nov 9, 2004 | 06:31 AM
tegmech's Avatar
i know the rc720 i had to modify the stock clips a bit to make it fit. I just used a soldering iron and it worked perfectly.
RICE POLICE SIP
Jan 1, 2006 10:05 AM
B18 CYA
Jun 23, 2004 04:15 PM
SpoolnG2
May 18, 2004 12:33 PM
yellowmonkeyboy
Apr 16, 2004 05:46 PM
