Oil Pump Failure
Old Nov 10, 2004 | 06:38 PM
NVturbo's Avatar
O.G. triple O.G.
Default Oil Pump Failure
I have just recently installed an OEM ITR oil pump about 2 1/2 months ago and now I have no oil pressure. The car shut off while I was driving...And when I was trying to start it back up...it would crank until the 3rd try. Once it cranked up, I noticed "0" oil pressure. Someone mentioned that it maybe the thrust bearing washers. Anyone else experienced this or have an idea of what may be wrong? I don't want to go out and buy components/parts that I don't need. By the way, my turbo setup is a B18B with Integra Type R oil pump (new from Acura dealer). Thanks in advance.
Old Nov 10, 2004 | 07:05 PM
fipracing_com's Avatar
Default Re: Oil Pump Failure (NVturbo)
WHat is the oil level on the dip stick?, also are you sure you dont have an oil leak some where. How long have you run the motor with 0 oil pressure? When did you loose oil pressure, did it happen right after you installed the new oil pump? Did you prime the pump? Provide us some more details on the situation?>
Old Nov 10, 2004 | 08:17 PM
Muckman's Avatar
Moderator in Chief
Are you using the stock harmonic balancer (crank pulley)?
Old Nov 10, 2004 | 08:23 PM
Default Re: Oil Pump Failure (Muckman)
2nd that, i hope he did put and under drive crank pulley on that motor.
Old Nov 11, 2004 | 07:07 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Oil Pump Failure (fipracing_com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fipracing_com &raquo;</TD></TR><TR><TD CLASS="quote">WHat is the oil level on the dip stick?, also are you sure you dont have an oil leak some where. How long have you run the motor with 0 oil pressure? When did you loose oil pressure, did it happen right after you installed the new oil pump? Did you prime the pump? Provide us some more details on the situation?&gt;</TD></TR></TABLE>
I do have oil on my dipstick. No, I don't have an oil leak anywhere. I lost oil pressure after my car shut off. Once I cranked it back (after the 3rd try), I noticed 0psi of oil pressure. I checked the nylon oil line (oil pressure gauge) and there was no oil running through it. Like I said before, I have been driving the car with the new OEM ITR oil pump for over 2 months now....of course until the other day!!!
Old Nov 11, 2004 | 07:08 PM
NVturbo's Avatar
O.G. triple O.G.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Are you using the stock harmonic balancer (crank pulley)? </TD></TR></TABLE>
NO...I am using a OEM Honda Civic Type-R (single belt) crank pulley.
Old Nov 11, 2004 | 07:09 PM
m R g S r's Avatar
What crank pulley were you using? Pull off the oil pump, and disassemble it to make sure the gear is still intact.
Old Nov 11, 2004 | 07:15 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Oil Pump Failure (m R g S r)
OEM B16B crank pulley. I will remove it and check the oil pump out next weekend since I don't have time this weekend. DOwNTimE sucKs!!!!
Old Nov 17, 2004 | 01:59 PM
NVturbo's Avatar
O.G. triple O.G.
I researched some more and still have not found a logical reason why the (was brand new) OEM ITR oil pump failed. Anyone else out there have any other suggestions? I don't want to get ProDrive gears and have them get torn up also....!!!
Old Nov 17, 2004 | 02:07 PM
Jared's Avatar
killed oil pump gears are normally a sign of killed thrust washers, loose flywheel bolts, loose crank pulley bolt, bad balancer.
Old Nov 17, 2004 | 03:00 PM
vtekstorm's Avatar
Default Re: Oil Pump Failure (Jared)
did u prime the oil pump when u installed it?
Old Nov 17, 2004 | 03:44 PM
Flr Power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">killed oil pump gears are normally a sign of killed thrust washers, loose flywheel bolts, loose crank pulley bolt, bad balancer.</TD></TR></TABLE>
How would loose flywheel bolts create oil pump failure in the first place?
Old Nov 17, 2004 | 06:42 PM
Jared's Avatar
Default Re: Oil Pump Failure (coocoo32)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coocoo32 &raquo;</TD></TR><TR><TD CLASS="quote">
How would loose flywheel bolts create oil pump failure in the first place?</TD></TR></TABLE>
by slamming into the crank and creating bad thrust loads and horrible unbalanced crank harmonics. think about how your car would drive at high speeds if you left a wheel loose.
Old Nov 18, 2004 | 12:35 PM
Muckman's Avatar
Moderator in Chief
Hes basically saying any kind of abnormal vibration or wobble can destroy oil pumps.
Old Nov 18, 2004 | 08:10 PM
NVturbo's Avatar
O.G. triple O.G.
That's what my cousin said also. I am just waiting for my NEW oil pump to get here so I can slap it on. I just hope it doesn't happen again because it's a freakin hassle just to replace the damn thing!!!
Old Nov 20, 2004 | 03:48 PM
Jared's Avatar
And if the car is daily driven I also suggest you ditch the N1 pulley.
b20eghatch
11
Jul 12, 2010 11:24 AM
wickedplastikman
Feb 20, 2009 02:40 PM
sleepyhatch00
Sep 2, 2005 01:35 PM
iwouldHITit
Jul 17, 2003 04:11 AM
Tofurky
Jun 23, 2003 12:44 PM
