engine is being loaded with fuel. What's the deal?
I recently finished assembly of a brand new motor (B16 .020 over, CP 9:1's, eagle rods, etc.) and am currently trying to start the engine, with no luck. The setup that I had before I did the rebuild was identical to the way it is now in regards to fuel management, plugs, etc. The only difference is a new manifold, downpipe, and the lower compression. I"m using teh AEM for the ecu, and again, its using the same calibration that I had before, no changes were done. When I tried to start up the engine, it would sound like its trying to start, but I get nothing out of it. just a couple of sputters, and it dies. When I pull my plugs, I pull out plugs that are dripping with fuel, I'm just getting a crazy overload of fuel in the cylinders. The strange thing though, the odd time I pull a plug, I'll get white smoke pouring out of the plug well. What could this possibly mean?
Things I've tried so far:
Checked the timing on the engine, cams are lined up with #1 tdc.
Replaced plugs/wires
Cleaned out the dist. cap contacts
Adjusted everything I possibly can in the ems to lower the fuel.
My next steps, are to swap out the 450s' with another set, I could possibly have a faulty set of injectors,
If that fails, I'm going to try switching back to the stock ecu and stock injectors. But aside from that, I'm clueless on what else I could possibly do. Is there a chance that an unplugged clip could be causing the trouble, or some other wiring defect? Is there anything else I should be looking at?
Re: (PK SPEED)
I don't think so, for ***** and giggles I tried out the stock ecu on the setup and it was even worse. before the build, I needed the stock ecu for a bit, and it could start the motor no problem and run the 450's, although it was super rich. This time, I get way more luck with the aem then the stocker. At least, with the ems, it sounds like it has potential to turn over
Re: (B-16A)
there is no way a stock ecu could idle, even start a car that has 450cc in jectors installed.
stock ecu dumps 100% fuel at start up wich = 240
and if u had the 450 in it would flood.
so something you are saying is not accurate.
if u have the AEM as an EM you should lean out the start up & idle air pressure colums.
Re: engine is being loaded with fuel. What's the deal? (Canuk_SiR)
Have you verified that you are actually getting spark? Wires in correct order?
What does your fuel pressure look like, assuming that fuel is the problem indeed?
kaputhonda
11
05-31-2013 12:33 PM
